Click for Northern Lights Click for Westport Click for Furuno Click for Mulder Click for Mulder
Changing out Trim Master Tab pump
Discussion in 'Luhrs Yacht' started by CaptainChase, May 8, 2020.
  1. CaptainChase
    CaptainChase Member
    Seabrook, TX
    Currently have the original Trim Master trim tab pump installed and it is not working model # 200200350. I believe they are also discontinued. Was curious if anyone has found a good replacement that is similar
    Try changing your title to include Trim Master in it and might get more response. I don't think you'd have any issues swapping out the appropriately sized Bennett pump, the pumps are pretty simple technology.....they pump fluid out to push the tabs down and they suck it back to retract them as well as having a few solenoids to open and close the circuit.
  3. Capt Ralph
    Even the old Boat Leveler and Bennett pumps will work.
    All work with a reversible DCv motor and P & S solenoids.
    If I recall there is a good second shop near you. Tap on them for any oil pressure tab pump.
    OTOH, Can't be much wrong. Was simple enough a pump. 2 beers and a DVM should get you to the bad wire.
  5. CaptainChase
    CaptainChase Member
    Seabrook, TX
    Thanks for all of the replies. All wiring was good, going to go pick up the Bennett pump here shortly and swap out
  6. rtrafford
    rtrafford Senior Member
    Vero Beach
    That's probably the fastest and easiest and most certain path forward. Have you checked the tabs for freedom of movement? Sometimes the hinge systems of tabs can be essentially welded into place with paint buildup over years. Might give that a quick look, too.
  7. CaptainChase
    CaptainChase Member
    Seabrook, TX
    Yes I did, thank you. Tabs come down with a pull and retract back themselves. Old pump is getting proper power with tabbing up and down each side, pump has just gone bad. On to the next project!
  8. rtrafford
    Vero Beach
    No worries, and glad the issue was quickly resolved. We took pneumatic tools to my hinges to free them from binding, and one set of pistons had to be replaced as it failed trying to push a tab that wouldn't move. Learned the hard way. You look at those things on the hard, and they just look like they work and your mind races right past them. Good that you checked yours. I completely overlooked mine...
