Click for Comfort Click for YF Listing Service Click for Mulder Click for Perko Click for Mulder
Catalina 426 - Removing rear gas tank under aft cabin
Discussion in 'Chris Craft Connies, Commanders & Catalinas' started by PhilipSchultz, Sep 21, 2020.
  1. PhilipSchultz
    PhilipSchultz New Member
    Memphis
    I need to remove the rear gas tank that is under fresh water tank and under the bed in the aft cabin. The gas tank is leaking and it needs to be replaced. Any advice for disassembling the rear bed and removing the water tank and then the gas tank?
    Don't make any sparks :D
  3. NYCAP123
    I would drain off the fuel, pour in some Dawn, fill with water, drain off into barrel and use pads to remove fuel from the water. Repeat until clear of fuel.
  4. boatpoor
    boatpoor Active Member
    You'll never wash the gas fumes out. Purge it with an inert gas such as argon or nitrogen.
  5. Capt Ralph
    Lots of high volume air blowers, blowing OUT. Fresh air will find a way in.
    Turn all power (AC&DCv) off. Run the blowers on deck from shore power.
    You are working with GAS fumes. Don't be a statistic, do it rite, proper and safe.
    No metal to/on metal tools; no steel on a steel chisel (no sparks).
    My cordless tech tool makes internal sparks. When you get low in the bilge, hand tools (screwdrivers) only.
    This forum has seen enough gas boo boos.
    Ah, take lots of pictures and share here. We like to watch...
