Click for Abeking Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for Delta
Cat D353's
Discussion in 'Engines' started by cabobo09, Feb 21, 2010.
  1. cabobo09
    cabobo09 Member
    Cabo San Lucas
    Anybody old enough out there to run these CAT engines? Appreciate any info you have.
  2. Marmot
    They are simple enough a teenager can run them.
    Did you buy an old dozer, a generator, or a shrimp boat? There are enough around that you can still get parts engines and running takeouts.
  3. K1W1
    Wooooooooho :))
    Had one that had an after cooler failure filling No 2 with water, blew the head gasket out the side and carried on albeit a bit untidy
    Tough old girls.
    What do you want to know exactly?
  4. Henning
    Henning Senior Member
    Ft Lauderdale FL
    Had lots of them as gensets running between 399 Cat prime movers. Simple solid little engines, what do you need to know?
  5. cabobo09
    cabobo09 Member
    Cabo San Lucas
    Looking at a Benetti with a pair of these old girls and am basically looking for what you guys have said. A review of the records and a solid engine survey will tell the story. They're definitely don't sip the diesel like the newer models.
  6. Henning
    Ft Lauderdale FL
    That is true, electronic controls have seriously increased fuel economy on modern engines, the side benefit to that is also a major reduction in soot on the boat. Both of these issues can be addressed to an extent by getting the prop pitch just right. Typically a smoking/fuel hog will have too much prop pitch which will keep the rack pulled further open than optimal.
