Click for Abeking Click for Burger Click for CL Yachts 99X Click for Glendinning Click for YF Listing Service
Cat 3196 steering pump
Discussion in 'Engines' started by Rolo Tomasi, Jan 22, 2020.
  1. Rolo Tomasi
    Rolo Tomasi Guest
    I’m looking for a replacement steering pump for a Sunseeker with caterpillar 3196 660 hp. The original is a Hypo Marine model HM1886/8 from the UK which is difficult to find. Maybe some other brand?
    What steering system do you have (Hynautic or Capilano)?
  3. Rolo Tomasi
    Rolo Tomasi Guest
    Not sure. Hypo Marine is the steering pump and reservoir.
    Power steering assist pumps may look the same on the outside. May share same casting numbers but pending the brand and specs of the system it is working for, may have many different internal parts and or adjustments internally, providing different flow, pressure and pressure relief.
    Knowing more about the system vendor could help in trouble shooting your system or getting support and recommendations on replacement pumps.
    Witch brings up the next question; unless your pump is physically damages and in un-repairable condition, why do you thing it needs replacement?
  5. Capt Ralph
    You ever make your trip? How did you do and what numbers did you find?
    You can answer back on the original post.
  6. Rolo Tomasi
    Rolo Tomasi Guest
    Waiting on the steering pump issue to be resolved.
    Mod edit: duplicate information removed
  7. Rolo Tomasi
    Rolo Tomasi Guest
    It's probably repairable but we were looking for a faster option. Also, the boat is about to make the trip down the Baja and would prefer a new pump.
