Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for Furuno Click for Abeking
cast iron vs. aluminum manifolds
Discussion in 'Technical Discussion' started by lanaperkins, Jun 28, 2011.
  1. lanaperkins
    lanaperkins New Member
    United States
    I would like to know if anyone has an opinion regarding the benefits of replacing the manifolds with cast iron vs. aluminum?
    Don't use Aluminum. Mercruiser had the bright idea of going to aluminum manifolds and ss riser on the 8.1 Horzions. They had a huge issue and recall from them prematurely failing, as in 2-3 years and leaking into the motor. They went back to cast iron manifolds and still use the s/s risers. Do a search on the internet about them.
  3. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    If we're talking exhaust manifolds here, then ditto.
    J & T tried this in the mid-eighties on 8V92s with predictably sad results.
  4. jhall767
    jhall767 Senior Member
    Middle River MD
    On what? Assuming its an engine you usually go to aluminum to save weight and allow for better flow as you can customize the passages much easier. Aluminum expands at a different rate than cast iron so this must be accounted for in the design.
    On most boats saving a few pounds isn't going to make any difference. On the reverse side my buddy's 68 mustang (390 cid) had a 90 lb cast iron intake manifold. Changing to aluminum saved about 70 pounds with more hp and better handling to boot. So it all depends on the situation.
  5. Jorge Lang
    Jorge Lang Senior Member
    Loren, you can go one up from the old J&T cast elbows. We have replacements available in 316L stainless that not only reduce weight, but also last much longer.
  6. lanaperkins
    United States
    Thanks, for all the info.
