Click for Nordhavn Click for CL Yachts Click for Walker Click for Northern Lights Click for Burger
Carver Voyager 450 Volvos Multi Station Unit
Discussion in 'Carver Yacht' started by Still AOK, Sep 16, 2011.
  1. Still AOK
    Still AOK New Member
    Thunder Bay Ontario Canada
    Hello
    I am looking for the location of the multi station in my carver 450 voyager pilothouse - anyone know the location of the unit in the vessel with the TAMD74P volvos? My second driving station is kicking out on start up
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Sorry, I should add something. The module is normally stuck somewhere stupid in the foreward flybridge locker/deckbridge joint.
  3. Still AOK
    thanks
    thanks for getting back to me so quickly!!yes it is the EDC module (by which I assume you mean the Multi Station Unit -the device that allows you to switch between driving stations) - what do you mean by the "forward flybridge locker/deck bridge joint"?. I have looked under the lower and upper helm stations numerous times? Volvo has explained to me what it looks like and I have still had no luck.
  4. Fishtigua
    Guernsey/Antigua
    Just follow the cables down. Some makers (not sure about Carver) even fitted them in the deckheads above the lower helm.
    It's a nasty job but some sucker has to...........:mad:
  5. jlplatts
    jlplatts Member
    St. Pete FL
    We have a 2001 Carver 444 with Glendinning controller. The electronic control units are mounted on our boat are in the engine compartment forward of the port engine.
  6. Still AOK
    thanks
    I am looking for the throttle control unit - are you referring to the Glendinning Cablemaster?
  7. Fishtigua
    Guernsey/Antigua
    If you have Glendennings, talk to them.
    If you have the very old Volvo system, check out a local dealer.
    Do you feel it's an electronic fault or a cable movement promlem?
  8. Capt Ralph
    The cable-masters are for the shore power cables.
    On the older engine control systems, Glendinning also made the mechanical engine synchronizers. Large shoe-box sized Cozmo with throttle cables attached. The ECM modules were sometimes mounted close to this big gold looking box, usally near the engines.
  9. jlplatts
    jlplatts Member
    St. Pete FL
    Correct, we have the Glendinning synchronizers. The throttles are electronic with the ECM modules mounted in the engine compartment. From the control boxes there are mechanical throttle and shifter cables. I guess my point was that on our Carver the control boxes were mounted in the engine compartment. It might be a clue to how Carve did things if there is any consistency in what they do.
  10. Still AOK
    thanks
    I have all volvo systems (TAMD74P with EDC) - have looked in engine room but will look again thanks
