Click for Nordhavn Click for Ocean Alexander Click for JetForums Click for YF Listing Service Click for Mulder
Carver steering
Discussion in 'Carver Yacht' started by captnrontx, Aug 20, 2012.
  1. captnrontx
    captnrontx New Member
    Lake Texoma
    My 1991 Carver 370 MY has a rough steering radis. It feels like the cables are bumpy as I turn the wheel.
    This thread has been moved to the Carver forum, where it should have been posted to begin with.
  3. Pascal
    Cables on a 35/40 footer? I doubt it... Should be hydraulic. Check fluid level, if you can't figure it out at least tell us what kind / brand of steering system you have
  4. RT46
    RT46 Senior Member
    not sure about Carvers, but i had a 35 Viking with cable steering that was very reliable, the only draw back was finding an auto pilot for a cable steered boat that size and displacement. The Carver is mostlikely much lighter than the Viking.
  5. talexander38
    talexander38 Member
    Va. Beach / Deltaville Va.
    sounds like you need to pump up the system,
  6. Phillip J
    Phillip J Member
    Mariner's Marina, Seneca, IL
    I agree with talexander.
    Check your air pressure in the steering control mechanism, it is usually located in the Aft Cabin under the night stand. Should be around 20 lbs of pressure. I keep a small sports pump on my boat just in case it gets low. Usually have to check and fill it to proper pressure at the beginning of the season.
  7. RB480
    RB480 Senior Member
    New Buffalo, MI
    In your boat it should be accessible through the lounge seat next to the drawer set that the head door hides.
  8. captnrontx
    Lake Texoma
    Thanks for the advice, I will check it out. It feels like a rough cable running over a pulley.
  9. Pascal
    Some hydraulic helm may feel that way as it s really just a pump.
  10. MysticDolphin
    MysticDolphin Member
    Lake Texoma
    not to steal the thread.. i have the 4207 and cannot find the resevoir... the manuel says it is at the wheel... but not no mine... any suggestions?
  11. Pascal
    You may not have a separate reservoir. Sometimes the helm itself is the reservoir
