Click for Westport Click for Walker Click for Delta Click for CL Yachts 99X Click for Burger
Carver alternator output
Discussion in 'Carver Yacht' started by timjet, Mar 5, 2012.
  1. timjet
    timjet Member
    Tampa, FL
    Does anyone know how Carver designed the alternator output on the Carver 355 ACMY 98 model diesel powered. I need to know if the alternator output voltage from each engine goes to the battery selector switch and then to the selected battery bank or if the voltage goes directly to each battery bank ie; left engine alternator to left bank and right alternator to right battery bank, by passing the battery selector switch.
    Thanks, Tim
  2. garyohv
    garyohv New Member
    Florida & Oregon
    To determine if one engine is charging multiple batteries, attach a voltmeter and note if voltage jumps when an engine is started. Most likely all batteries will receive a charge from either engine with the use of battery (charging) isolators.
