Click for Ocean Alexander Click for Burger Click for Ocean Alexander Click for Northern Lights Click for JetForums
Carver 356 Aft Cabin shower water leaking on to interior
Discussion in 'Carver Yacht' started by Reelpriority, Mar 20, 2014.
  1. Reelpriority
    Reelpriority New Member
    Hilton Head Island, SC
    Noticed a blue/gray stain at base of exterior wood panel wall which is the other side of the aft cabin shower. Lifted carpet away from the panel and detected moisture. Shower drain floor is not overflowing. Sump is new and works well. Only possibility is seam at the bottom of the fiberglass enclosure, but it looks fine in terms of the seal. Another thought was water draining down the plexi glass door and traveling along the piano hinge and dripping onto the lip of the shower drain pan. Anyone have this problem on a 355 or 356? Thanks
    It's the caulking. Take a small tie wrap and run it push it along the seam, you'll find there will be large area's you can stick it right through between the fiberglass and the caulking.
  3. roblou15
    roblou15 New Member
    san diego
    I had that issue you need to caulk around the door and at the base pan
