Click for JetForums Click for Walker Click for Mulder Click for Mulder Click for Westport
car alternator welder
Discussion in 'Technical Discussion' started by sharkbait, Oct 25, 2011.
  1. sharkbait
    sharkbait New Member
    taree
    Hi All
    we bought our first yacht yesterday steel hull 27ft $560
    What can I say...
    "I think I need a tetnus injection from just looking at it"
    the outboard motor the engine will run but the rest is stuffed
    I NEED A WELDER,
    My boat needs hot water so i am going to use the outboard engine's water cooling system as the heater.
    The shaft I will pair to a 12Volt 200Amp car alternator as a charging system
    My question is can I remove the rectifer and with the 3 coil windings inside bridge them together attaching a welding cable/hand piece and use it as a MMAW or ARC stick welder?
    basically open circuit the windings and closing the circuit through the welding rod.
    If I added 200Amp rated diodes and bridge the circuit after the diodes (soldering the diodes A/K respectively to the coil terminal and the other to the welding lead) could this protect the coils from burning out? assuming I want to take the power factor losses.
    Can anyone tell me if any of this works or how to make a welder from car alternators?
    The above is my best guess and i need a very lightweight 12V generator and a welder this will solve all my major problems
  2. PropBet
    PropBet Senior Member
    Is Everything!
    Car battery + jumper cables = welder.
    Google it. It's very common in the off road circles.
    It's also a lot easier to understand than your post.
  3. sharkbait
    taree
    this battery method has problems:
    it will cause a arc & weld but you have little control over amps at the electrode, the controler needed would be expensive and batteries take time to charge, quick to flatten & you can destroy the batteries life especially in deep cycle batteries
    I have a good 10hp outboard motor- gear box & bottom end is stuffed
    it will drive 3x 200 Amp alternators and it is a very good weight and size
    I can use this to run everything on the boat and charge the batteries.
    water cooled- I have hot water heater for onboard shower as a by product
    It will run a inboard electric motor
    if it will weld it is perfect for my needs
    As for ease to understand, all I need is one person who knows and others may be interested as well.
    I should note however it maybe 12 volts but the amps are the same as any welder, If you dont understand it, then you probably shouldn't be playing with it.
    motors, shaft/propellers, batteries, inverters, transformers etc. have safety factors
    you can tell someone not to stick their hand in a moving motor, fan, shaft or propeller.
    don't install inverters, or re-wire the 240Volt sections of their boat etc. etc.
    but will everyone listen?
    it goes for any post for advice, especially of repair- machinical or electricial including batteries as they can blow acid with explosive force, if not maintained and used properly.
    PM me the answer if you wish,
    I am 9 months shy of my electrical trade papers (4year apprentice)
    I no longer work in field due to injury & I'm not 100% sure of the answer.
    Everything I was told on my first day holds true-
    1. There is never any harm in asking a question, just ridicule.
    2. the difference between a live electrican and a dead one is:
    3. every wire including neutral links and earth wires could be live, become live at any time,
    4. ALWAYS treat wires as LIVE.
    5. always respect electricity and any machinery,
    6. If your NOT 110% SURE don't gamble, find out.
    7.Any monkey can wire a circuit, but it takes a trained person to know how it works and do it safely, and properly
    It was/is brutal, but near the end of my 3 year I opened the main board up and the neutral link and earth was live, and I'm still here to state the facts.
    NO OFFENCE to anyone intended, just calling it like I see it.
  4. Old Phart
    Old Phart Senior Member
    I dunno
    Have alternator - need welder
    Picture is worth a thousand words.
    Homemade DC Arc Welder Build - YouTube
    P.S. - Right sidebar will provide some extended viewing.
    Hope this helps.
  5. RT46
    RT46 Senior Member
    im not really sure what all that stuff is.....
    but its totally cool and I wish I could make stuff like that.....
  6. sharkbait
    taree
    The beautiful thing is that now you are aware it can be done you can always go to a electrican auto/domestic and show/tell him and it shouldn't cost much to do.
  7. PropBet
    Is Everything!
    Neither does a 110V MIG welder and a gas powered generator to run it. Oh, and both items are standard, functional, off the shelf items. No brain damage.
    It is a genetic flaw that the human race overlooks the simple route from "A" to "B".
  8. Marmot
    Given the availability of low cost new or used "buzz boxes" and the quality of weld produced by a small inverter unit, or the versatility of a decent little wire feeder I really can't understand why anyone would want to waste filler material and time, and sacrifice quality, just to MacGyver a way to waste thousands of dollars to produce weak and porous welds.
    :confused:
  9. Capt J
    +3, a portable stick welder is cheap....... why try to play mad scientist and get poor results.
  10. sharkbait
    taree
    I have a MMAW, MIG and 8kVA generator, Yes they are small but extreemly heavy and I dont really have the room for it all.
    The alternator generator/welder, will run everything including the main drive propeller via sinc a motor to it. it isnt MAD scientist stuff generator/welders have used the same prinicipals for decades.
    AS for porosity in welds ect.. if you have the right amps, surface prep, and dry electrodes then it comes down to skill of person welding
    80Amps produced by this type of welder is the same as 80A produced by any other method.
    Why do people think it is some how different or strange to want space saving, and multiple use equipment on board.
    it may not be normal to drive the main shaft from electric motor instead of diesel, but it will be some day.
  11. 42hatteras
    42hatteras New Member
    New London Ct/Hope Town Bahamas
    As a welder and mechanic of over 40 years,yes all you ask for and suggest can be done.I have made an emergency weld with a 12volt battery/welder,but the duty cycle was just about nil and it could not be used for a job of any size. I guess what I'm getting at here is exactly what are you going to use it for?
  12. sharkbait
    taree
    I started as a metal fabricator & welder, but as I needed to dis/re connect motors etc.. to jobs I needed a electrical class lic to do this so it lead to a second apprenticeship
    what i am looking for is to dump my big generators, welders etc.. and have one unit operating everything
    1. through the rectifier to charge the batteries
    2. open circuit to run a emergency welder, this is to weld a plate up to 500x500x2-3mm to patch the hull if ever needed or for small general maintaince
    3. run a electric motor to main drive shaft power the craft when not in sail
    4. use the water cooled engine as a hot water heater for shower.
    5. keep the engine out on deck and out of the cabin.
    I guess I want alot of different things, cut down space required ect.
    As the internal motor will work from battery, I dont need to fire up the motor to moore or dock, I can use battery and let the solar system recharge the batts over a few days
