Click for Northern Lights Click for Furuno Click for Burger Click for Burger Click for Mulder
Captain Rates (day rates, maintenance, services)?
Discussion in 'General Yachting Discussion' started by Ron Cardoza, Oct 1, 2018.
  1. Ron Cardoza
    Ron Cardoza Member
    Hello,
    I'm new to boating and need to understand the rates for Captains and services provided by Captains. I just closed on a 2015 50' Prestige Flybridge twin Volvo IPS 600 434 hp each. Pods and 3 joysticks (cockpit included).
    I'm located in Fort Lauderdale Florida and will be keeping the boat on a slip close by (sunrise area).
    I have limited experience (boat safety class, in water training on 27' center console single engine, in water training 45' twin engine bridge but just a couple of hours here and there) pretty green and want to get up to speed in captaining the boat myself independently. I want to learn using the thrusters first before really using the joysticks. There's a lot to learn from electronics, navigation,
    - Any idea on what the avg charges for day rate (pleasure cruising but also training me on running the boat)? - Is there two separate charges for just pleasure cruising vs. training?
    - What is a day rate? how many hours is a day (prepping, running and closing up)?
    - Overnight trips rates?
    - Delivery trips (fort lauderdale - bahamas or Keys & return?
    - Maintenance; what is the avg rate for general cleaning the exterior of the boat and how often should that be done (per week or every other week)? Is there a avg per hour rate?
    - Same for interior cleaning?
    - Is there a change in rate for exterior buffing, compound and waxing vs rate for just general cleaning?
    - How often should a boat be buffed, compounded and/or waxed? Heard it's best to keep up with to keep Bristol condition.
    - I believe the hull is gel coated. and I would like to get a complete bottom job (scrubbed, painted, props, waxed etc) and then have a regular maintenance plan to keep it up.
    - How about engine work avg rate and how often needs to be done?
    Am I missing anything?
    I sooooo appreciate feedback!
    Also if there are services that can be conducted by others that may not be necessarily Captain services like detailing , which may reduce the cost but at same time deliver the quality of work needed.
    Thank You!
  2. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    A suggestion: learn to dock the boat WITHOUT thrusters first... then carry on to thrusters, then joystick.
    To the rest: it depends. For instance, I charge different rates for cruising versus training. And note, skill are different (driving/docking/etc. a boat, contrasted with teaching). Maintenance is often completely separate, often not really "Captain's work," and I don't offer that; no one should pay my rates to get the boat washed/waxed or detailed, etc., and there are brand-specific engine or other systems specialists who can provide better service in those arenas than I could. And so forth.
    That doesn't address some routine or sometimes unexpected maintenance while underway on a delivery. Water pump impeller craps out, replace and carry on. Etc.
    -Chris
  3. Pascal
    I d say $300/350 a day for a smaller boat. Some captains may charge a little more if training is involved. Same on delivery and cruising. Routine maintenance and cleaning on delivery and cruising is part of the job
    Regular washes are usually done by boat detailers. In Miami, typical rates are $2 a foot for washes. Compound and wax typically $20 a foot for the hull and another $20 above rub rail. Usually once a year... monthly diver cleaning $2 a foot. Rates in FLL are often higher , like $3 for washes ans divers
    Bottom paint varies by yard... figure about $50 a foot for haul out, block, pressure wash, paint and launch. You can usually get 18 months out of it
  4. olderboater
    A lot of variables. I would expect a captain to charge a daily rate of $350-400 in the FLL area. Overnights would be same daily rate but I also expect tipping, especially on longer days and on trips. A day to me is 8 hours and when it runs longer, then I think if the rate doesn't reflect it, the tip should. I find most captains tend to lock themselves into a daily rate and don't appropriately charge for the 12 and 14 hour days.
    Delivery trips are the same, but most captains are going to take a mate at another $150 or so per day. Plus add in expenses as the captain and mate have transportation costs on top of meals and other daily costs.
    $2-$3 for washing, $2-3 for diving. The more frequently you schedule and commit, the lower the cost per time. A one time job is going to be at the high end or even more where as if you commit to every three weeks or four weeks the rate goes toward the lower end.
    Compound and wax, I'll go with Pascal's numbers although again if it's a one time job I'd expect to pay more versus if it's someone you use for regular washing. How often to Buff, Compound and Wax? I think some way over do them. Understand that compounding does remove finish. I don't believe in buffing or compounding until a boat ages and starts to show issues. Waxing depends on the paint. I believe the Prestige is gelcoat and, if so, then I'd say two to four times a year, depending on where it's kept and how used. Paint would be more like twice a year, unless Awlgrip which should be cleaned and treated but not waxed.
    Engine and equipment maintenance rates vary widely but in FLL I'd expect $100-$120 an hour on average. Now, routine work like oil changes should be less.
    One thing to consider with all the things to be done is perhaps using a captain who is also a yacht manager and can schedule and arrange all the jobs you've outlined for you plus make sure routine maintenance is kept up. The captain will not do the other work but will make sure it's done timely and right.
  5. Pascal
    Along this lines? I should also mentioned that when I stopped running a Johnson 70 full time and the boat was up for sale in FLL, I used Capt J to get routine maintenance done.
    I just didn’t have time to handle it from Miami and was busy full time. He did a great job handling and coordinating various things over a few months.
    It takes a lot of time, and good contacts, to get stuff done.
    Rule #1 of asking about boat services. Never piss anybody off.
    A novel could be written about rule #1 when asking for boat service. Just remember, they all talk and work with each other one time or another.
    Marine Grapevine... faster than the speed of life.
    Find a good recommended shop, pay quickly and tip well when you see an above and beyond effort.
    Any issues, a nice calm conservation should be had.
    There are some folks up here that can not get any boat washers, any time, any price. In one sentence I can explain why, The pissed them all off.
  7. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Question from the North.
    Do you guys tip the yard manager or the actual person doing the work.
  8. gcsi
    gcsi Senior Member
    tampa
    Pascal: Who is Cpt. J?
  9. Capt J
    For Captaining- the going rate is $400 per day plus expenses. Same price for training, deliveries or trips with owners (overnight passages would be more). Usually on trips with owners, they tip, and for good reason there is a lot more work involved at the dock. A day is usually 8 hours, 10 hours maximum or the Captain should be compensated more. I have many owners that will book me months in advance to deliver their yacht and/or wait until I'm available and will not let me even recommend someone else to do their trip. I also have some dealers and owners that will pay me more per day, and tip extremely well. I have one large dealer that pays me $500 a day to get priority. I started out charging $300 a day in the early 2000's and don't know anyone reputable that would work for that. That being said, the smaller boats should pay the same or more. If you're doing a delivery on a 50' compared to a 70', at the end of 8 hours running in the ocean you are BEAT from the smaller boats, everything hurts, you're physically exhausted. Whereas I just delivered a new 70' SF 300 NM's at 35 knots, a few weeks ago and when you get to the dock it's like you've been sitting in your living room all day. Whereas I ran a 36' Luhrs 5 hours up from Key Largo yesterday in 2-4' seas for an owner I've worked for, for at least a decade who won't let me subcontract another captain, and today it feels like I played in the super bowl yesterday.
    Compounding and waxing REALLY depends on what condition the gel coat is in, and the boat itself, nobody can quote a per foot price for compounding it without seeing it, straight waxing yes. Good waxes cost a lot more than cheap. Price out a gallon of rejex compared to the regular blue bottle of meguiars wax. You could get exactly what you pay for here. If you pay peanuts, you get monkeys and have nothing but issues. Same with washing, the going rate is $3ft on up. When my washdown guy went on vacation, I couldn't get any other reputable company to do washdowns for as cheap as $2 ft, and that's with 10 boats and companies I've done business with for at least 10 years. You don't make hardly any money off of washdowns, they're just a necessary evil. Washings every 10-14 days depending on where the boat is docked in Fort Lauderdale, some extremely dirty places I've seen it as short as every 7 days. The going rate for divers are $3 ft for traditional, $3.50 ft for IPS. The other thing you have to understand is that a 50' Prestige is a ball buster to wash, it takes as much time as most 70' because there are so many wingdings, stainless in hard to reach spots, windows, etc.,just the flybridge ladder and window behind it take 20-30 minutes to chamois dry due to access. One thing you have to understand, is someone can do thousands of dollars in damage in a minutes time using the wrong products. If they're some 18 year old aussie kid that you got from a crew house, what recourse do you have? That being said, I don't hire illegals, un-insured vendors/people, or people that aren't IN the marine business. I would say the rates in Fort Lauderdale are higher than Miami due to the last sentence. Almost every boat I've dealt with that came out of Miami was a total mess, many things and systems were "island engineered" instead of fixed properly.
    With IPS, I would have only the Volvo dealer service them. Annually.
    Mbevins- if you feel the person working on your boat or yard manager has done an amazing job, by all means tip them.
    GCSI- Capt J=me
  10. Pascal
    You have a point about smaller boats being tougher. I ve done many 18 hours stint on skylounge boats and was fresher at the end that after a 2 hours rise as a passenger on a 35kts sportfish!
