Click for Burger Click for YF Listing Service Click for Ocean Alexander Click for Westport Click for Nordhavn
CABO 43 2003 WIRING DIAGRAM
Discussion in 'Cabo Yacht' started by KIKE GONZALEZ, Sep 1, 2021.
  1. KIKE GONZALEZ
    KIKE GONZALEZ New Member
    Puerto Rico
    Any idea where I can get a copy of the wiring diagram of the CABO 43 FB 2003 - MANs D2848L403?
    Good luck with that. What exactly are you trying to achieve? What issues are you having?
  3. mapism
    mapism Senior Member
    Sardinia
    Sorry, I can't help with what you are looking for, but are you sure of the boat+engines model?
    I have the very same MANs on my 56 footer, and she reaches 33 Kts.
    Either there's something seriously wrong with the Cabo 43 if it takes 1600hp to move her around, or she must fly! o_O
  4. Ben Cooksey
    Ben Cooksey Member
    Mobile AL
    43 with MAN 900’s. After running 5 weekend trips the 43 is very load dependent(like most boats). 1/4 tank fuel half water with 12 people the boat screams 28-29kts at 1925rpm only 72-74% load 3/4 tab. Fishing load with everything full including fish boxes 7 guys and 150gal bladder in cockpit 1850rpm 18-19kts 82-84% load full tab. Next trip Moved the bladder to the bow made a huge difference, same load on the boat but 25kts at 78% load. Definitely running the bladder up front now. Seas calm for all trips
    what does the boat turn WOT with full fuel, full water and 2 people? It sounds to me like your over propped? Should turn 2350 rpms WOT in the scenario I just mentioned. Usually they slow down that drastically if you're over propped.
  6. Ben Cooksey
    Ben Cooksey Member
    Mobile AL
    Full fuel and water 5 guys not a fishing load she turns 2375rpm 33kts. 28x38 federals
    Then you're right where you need to be. As for the wiring, what exactly are you looking for?
  8. leeky
    leeky Senior Member
    Florida
    There are 2 guys discussing 2 issues in this thread. You addressed the speed issue for Ben Cooksey. The wiring issue is from the OP, KIKE GONZALEZ, in post #1. All aboard!:confused:
  9. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Perhaps the mods could strip and separate this so the original op doesn't get lost?
  10. Capt J
    Kike Gonzales got lost a long time ago. He hasn't replied since his first post.
