Click for Walker Click for Ocean Alexander Click for Nordhavn Click for Cross Click for Northern Lights
C18/1015 engine hours: CAT LCD display vs CAT hour meter
Discussion in 'Engines' started by xF_PP, Jun 22, 2021.
  1. xF_PP
    xF_PP New Member
    Moon
    The mechanical hour meters installed on the engines show both about 3000 hours, the CAT LCD DISPLAYS in the pilot house and on the flybridge show about 1250 hours. Visually, the engines and engine compartment look more like low hours.
    What could be accurate?
  2. xF_PP
    xF_PP New Member
    Moon
    The seller claims 1250 engine hours and explains the difference with starting keys in the switched-on position.
  3. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    I would talk to CAT. I don't believe anyone can mess with the hours in the CAT LCD display so I would tend to believe that source vs. a manual gauge. However, the explanation given by the owner doesn't make a lot of sense. If I understand correctly, the owner is stating the key was left in the on position without starting the engines for upwards of 1,750 hours? So the keys were left on for 73 days? I guess anything is possible but sure sounds odd.
  4. gr8trn
    gr8trn Senior Member
    OR/WA/CA/BC
    The seller must be on the moon too?
    Why on earth would someone advance mechanical gauge hours?
    This is odd, glad you are asking questions.
    When was the boat commissioned and is there a ships log that would give more idea as to the hours?
  5. Slimshady
    Slimshady Senior Member
    Lighthouse pt
    Get all maintenance records and warranty work records. They should all have hrs and date of work performed each time. The engine survey will be able to determine running hrs and a detailed report showing all engine parameters and hrs the motors ran at each rpm range. Only way to edit that data is replace motors ecu.
  6. Pascal
    I could be wrong but for the Hobbs meters to run I believe you need oil pressure to activate them.
    we replaced a cat ECU on C32s a 3 years ago and engine hours carried forward. Not sure if that was by designed or if it was programmed in by the Cat tech.
  7. Slimshady
    Lighthouse pt
    My understanding is first time you boot up most ecu's you can correct hrs to match old one, after that it's locked for good. Ask me how I know!!
  8. mapism
    mapism Senior Member
    Sardinia
    In one of the "pages" of the Cat LCD display, there is also the total fuel burnt through the whole engine life.
    If the owner kept a log of refillings, you could check the consistency.
  9. Capt J
    CATs had a problem at one point in time that with the keys on, the mechanical hour meters would run.........they updated software and so forth. Believe what's on the lCD displays.
  10. rtrafford
    rtrafford Senior Member
    Vero Beach
    Two responses here. First, the answer is inside the ECU of the engine, and a Cat tech can tell you during survey what's fact or fiction. Meanwhile, take him up on his explanation. Have him power up the electronics on the engines with the key, and allow you to witness his engine mounted hour meters advance in spite of the engine being off. That should be an easy path to the truth. Further, if he was the original owner, these hours should be verified in the Cat service logs on file with the mechanic that provided his service. Have that mechanic attest to the history...in writing...from Cat.
  11. rtrafford
    Vero Beach
    Believe but verify. The truth is inside the ECU and inside the service records. No one is buying a boat with new Cats and not having their warranty maintained by required services.
  12. Capt J
    The LCD displays, display the data directly from the ECM.
  13. rtrafford
    Vero Beach
    Quite obviously. But the ECM has a lot of historical data and logs. Not merely a number.
  14. Capt J
    Yes but as far as hours and total fuel burned go, it transmits it real time to the LCD cat display
