Click for Walker Click for Perko Click for Delta Click for Northern Lights Click for Glendinning
Bubbling batteries, is that OK?
Discussion in 'Technical Discussion' started by P46-Curaçao, Apr 15, 2016.
  1. P46-Curaçao
    P46-Curaçao Senior Member
    There is a long explanation to what is happening that I can not properly explain with the correct terms.
    Thru a normal recharge cycle, the bubbles are normal.
    When the batteries stop absorbing current, they should settle around 13.6 Vdc.
    You can check the Trojan Volt/charge profile and make sure your not over charging.
    If required adjust your charger or charger controller.
    Your question and video is a great reminder to all that flooded (wet) batteries must be watched and maintained with the proper level of electrolyte (distilled water).
