Click for Glendinning Click for Mulder Click for Mulder Click for YF Listing Service Click for Burger
Bottom paint on aluminum hulls in FL and Bahamas?
Discussion in 'General Yachting Discussion' started by Scallywag, May 26, 2022.
  1. Scallywag
    Scallywag Member
    Islamorada FL
    Looking to switch bottom paints. For the past 10 years or so I've been using ePaints SN-1 and I've never been thrilled about it. The first year I get good pretty good performance, but after 18 months it is basically rendered worthless. I haul out on schedule every 2 years for a bottom job.
    I thought I'd query the pool of tribal knowledge. I'm typically home in the FL Keys, but also South Florida and the Bahamas. What are people putting on their Burgers, Browards, Aluminum Chris-Craft Roamers, Strikers, etc...? Any recommendations on copper free antifouling bottom paint?
    Seahawk makes a good one for aluminum yachts. But 18 month lifespan for bottom paint is pretty normal.
  3. hat4349
    hat4349 Senior Member
    Tampa, Florida
    I have to agree with Capt J, I always used Seahawk on my Roamer. I'd repaint the bottom every winter though, so I won't try to stretch it into years.
  4. rtrafford
    rtrafford Senior Member
    Vero Beach
    I've been using Trilux 33, haul annually. Prop Speed on running gear and bottoms of trim tabs. Works well. SoFla, Bahamas, Northeast.
  5. Pascal
    Hull material aside it’s tough to get anything working behind 18 month in SoFl
    how many coats do you usually use? Maybe an extra 1/2 coat near the waterline?
  6. rtrafford
    Vero Beach
    I use two coats and then a third at the top 18-24 inches.
  7. Scallywag
    Scallywag Member
    Islamorada FL
    Thanks guys. With the move away from copper paint I was hoping there were some newer products out there with better performance that I was unaware of. Maybe I'll throw some cayenne pepper into my mix this year hahah
  8. olderboater
    Are you using ablative, hard, or hybrid?
  9. Scallywag
    Scallywag Member
    Islamorada FL
    I've been using ePaint SN-1 which is a hard paint.
