Wondering why all the underwater metals are connected to the internal bonding system except the rudders. When I hauled out in the Fall the rudder zincs had disintegrated after only a few months. Seems a flexible wire running inside from each rudder post to the inside lugs of the 'Diver's Dream' plate would be a good solution. Has anyone done this? Is there a good reason not to?
Mine are as you described. No rudder or shaft zincs. Everything protected by divers plate. Anything that touches salt water must be bonded.
Lots of boats have a flexible bonding strap to the rudders, lots do not. Long ago we were asked to ad bonding straps to a customers boat. Later, the results were longer living zincs on that boat. From then on, we understood it could be a benefit and offered it to many customers during 0ur new customer surveys. The knowledgeable customers ordered it, Some DIY, others felt not factory; leave it alone. Sadly, a mix of results came back from our customers and divers with, factory installed, installed later, no strap; Nothing that would point to a solid result. Just nothing ever resulted in anything negative after installing a strap. We have always felt any item thru the hull should be bonded and all inspected often.
We tried curling the strap at first but our final designs were #6 or 8 tined copper with green sheath. Shrink over a correct size crimp lug, played in a nice arc. Attached to the bonding point on the rudder shaft log and tiller bolt using bronze lock or star washers. Also conducting grease. Never had a fatigue issue. The curled strap would expand and look messy after a while. On some older boats like our Bertram, white cable was used to match the factory color code.
