Click for Walker Click for Westport Click for Glendinning Click for Burger Click for YF Listing Service
Boat Balls, how to get an 80' mast under a 65' bridge
Discussion in 'General Sailing Discussion' started by Norseman, Sep 17, 2011.
  1. Norseman
    Norseman Senior Member
    Palm Coast, Florida
  2. PropBet
    PropBet Senior Member
    Is Everything!
    I wouldn't do it on mine, but I've seen them before. At first in awe, and then in slight awe the second or third time.
  3. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    I think it takes a really big pair of balls...boat balls that is, to even consider trying that. Just watch out for the guy on shore with the rifle who shoots the ball right when you are under midspan. Then you'll be left holding your balls...not the boat ones. :cool:
  4. lobo
    lobo Senior Member
    outbound
  5. brunick
    brunick Senior Member
    earth
  6. Kevin
    I seem to recall one of the Volvo Ocean Race boats doing that a few eyars ago without using weights... they just canted the keel.
  7. Fireman431
    Fireman431 Senior Member
    East central Florida
    I wonder how much the mast loves that 4000 lbs being suspended from the tip?
  8. K1W1
    Have you thought how much load would be on it when running a spinnaker in a good breeze?
  9. PropBet
    Is Everything!
    You could hang 4X that if needed.
    There's a semi complex mathematical formula to figure it out based on wind speed, angel of attack, total sheet(s) surface area, ballast, etc. etc.
  10. Fireman431
    Amazing. I had no idea masts were that strong.
  11. PropBet
    Is Everything!
    Google Wind Load Calculator for more reading.
    Basically Load in Pounds = Sail Area * (Wind Speed )2 * 0.00431
    So mt Father's boat has roughly 1800 feet of mainsail, which at 20 kts of wind is 3100 lbs of force. Now add a headsail, jib, sock, etc.
    My comment earlier (the mast can support 4X that) was perhaps a slight exaggeration in that I'm not going to attempt to hang 16,000 lbs off the top of the mast, but I'm confident in their strength and are build to endure great amounts of pressure.
  12. Kevin
    I've found some actual load numbers from the VOR70 and ACv5 yachts:
    Volvo 70
    Forestay: 17 tons
    Runners: 13 tons
    Windward Shroud: 25 tons
    Mast Compression: 62 tons
    ACv5
    Forestay: 20 tons
    Runners: 12 tons
    Windward Shroud: 35 tons
    Mast Compression: 70 tons
    Albeit, these are race boats built far stronger than the average cruiser... but if they can sustain a load of 50-70 thousand pounds on the windward shroud then 4000 pounds isn't much at all.
  13. AnotherKen
    AnotherKen Member
    Canada
    Get the owner of the Maltese Falcon to show you how they do it, no balls required!
  14. dieseldan
    dieseldan New Member
    Anchorage, Alaska and Palm Beach County, FL
    There is a way to heel a boat sufficiently for the mast to pass under a bridge with no balls required!
    Line the deck on one side with empty barrels and fill them with water until the mast is sufficiently heeled.
    To gauge the amount of heeling a weighted line a foot or two shorter than the bridge clearance height is attached to the mast head.
    As the mast heels this line hangs like a plumb line over the water. When the weight of the barrels causes the weight to touch the water,
    the mast will clear the bridge.
    This technique is used at the Port Myakka 49' horizontal lift railroad bridge on the Okeechobee Waterway in South Florida.
  15. dieseldan
    More Boat Balls
  16. Capt Ralph
    I used to help push botes thru that bridge in the 90s. A bunch of kids would come out from Indaintown Marina and load the boom. One mast we pulled over from a work boat, Just made it.
    The funny thing, we would come back out to clear the keel the same way.
    SFBs.
  17. Pauline
    Pauline New Member
    California
    Maybe I am retarded asking this but at low tide wouldn't you have more clearance than at high tide so is there any dates that where there are minus low tide I am very ignorant in knowledge and would be interested to know more about that
  18. Capt Ralph
    The Okeechobee Waterway levels are controlled by drought and its canal locks that try to keep the water level up.
    There is no lunar tide here.
    Hope this helps.
