Click for Cross Click for Westport Click for JetForums Click for Delta Click for YF Listing Service
Block heater melt down
Discussion in 'Engines' started by CTdave, Aug 2, 2021.
  1. CTdave
    CTdave Senior Member
    Greenwich CT/ Stuart FL
    Has anyone had a heater literally melt down?
    I recently had an overheat (Hatteras 50c 12v183 MTUs). I had been idling watching fireworks then it happened just minutes after getting up on plane. It heated up super quick then the coolant cap released, blowing out coolant steam. Once cooled down, I temporarily filled the system with water but heard water pouring out & discovered the plastic housing of the heater was completely melted down.
    What came first, chicken or the egg? Did I overheat, loose coolant then the heater went or did the heater go (dumping coolant) resulting in the overheat? These heaters have internal thermostats to control them so my only theory is that the thermostat failed and cooked the heater.
    I just installed the new heater & will be filling the system tonight. When I had temp water in the system, I started it and everything appeared normal & it was pumping plenty of water. I’ll finish up later & run it while closely monitoring everything.
    why do I get the weird issues?
  2. BRyachts
    BRyachts Member
    Ft Lauderdale
    Why was the block heater on if the engines were running?
    d_meister likes this.
  3. DOCKMASTER
    DOCKMASTER Senior Member
    Ketchikan, Alaska
    This was my first thought as I was reading. Then secondly, even if left on and even if the thermostat in the heater failed and stayed full on I would think it wouldn’t be enough to overheat the engine. The block heaters are usually like 1000 or 1500 watts. Your cooling system should overcome that. I think more likely culprit here is something in that heater failed and caused you to lose coolant/water and that’s why you overheated.
  4. RER
    RER Senior Member
    Newport Beach CA
    The way I read it I think that’s the question the OP is asking.
    One scenario, heater element failed causing loss of coolant and engine overheat. Repair heater and service cooling system and hopefully that’s the end of it.
    The other scenario is an engine/cooling system failure causing overheat which also destroyed the heater element. Damage to motor/cooling system TBD. Given a choice I’d pick the first one.
    I think running with block heaters on is a non-issue. People forget to turn them off all the time.
  5. DOCKMASTER
    Ketchikan, Alaska
    Yes, I agree that in theory the thermostat should simply shut the heater off as the normal engine cooling temp is well above where the thermostat kicks off. However, I have always been in the habit of turning the heaters off before I start my engines. There is no reason to leave them on and this issue is possibly a perfect example of why not to leave them on. Not to mention you are adding load to your gen if the thermostat fails and keeps the heater on. And if you have external heaters plumbed in you should have valve protection that you can close so you don’t lose coolant in the event of a failure of the heater, hose or connection.
  6. rtrafford
    rtrafford Senior Member
    Vero Beach
    I agree that Id pick the first one. That heater is designed to get hot, handle the temps. My guess as well is that the heater failure lead to a fluid discharge that allowed the engine to overheat.
    Running with the heaters on should be avoided, but it also shouldn't cause damage. More hours unnecessarily on a heater shortens its life span, but it shouldn't cause damage unless the type of failure you experienced takes place.
  7. Capt Ralph
    The Kim HotStart instructions states not to run the heaters after the engine is running to avoid damage.
    No further notes on what is damaged.
  8. CTdave
    First, thanks everyone for your thoughts!,
    Ralph, yes, I did read that on the new Kim Hotstart. I’ve never turned them off before but will do so. In the mean time, it looks like there’s a more serious issue as a result of the overheat. Coolant in oil
    This calls for the pros, I’ve contacted my MTU guy & he will be down to diagnose later in the week. There’s only a few po$$ibilities that I can think of. If it were one of my performance GM big blocks from my younger offshore racing days , I’d have the engine out, rebuilt and running on my own by now but these big boys are a bit beyond me.
  9. DOCKMASTER
    Ketchikan, Alaska
    Oh man, so sorry to hear. How many hours on that engine?
  10. CTdave
    Only 840 since a major
  11. mapism
    mapism Senior Member
    Sardinia
    +1.
    The opposite scenario of an engine overheat for some other reason, melting the heater as a consequence, is totally implausible.
    Temp gauge and alarm (which BTW are connected to separate probes, on that engine) should have gone through the roof well before the coolant becomes hot enough to melt the heater.
    Assuming that the coolant CAN get hot enough to melt the heater, which I'm actually a bit skeptic about.
  12. mapism
    Sardinia
    Sorry to hear that.
    Can you remember what sort of temp the coolant reached, and possibly also oil temp if available?
    Besides, for how long approximately did the engine run hot?
  13. CTdave
  14. mapism
    Sardinia
    Ok, but in principle the engine should withstand a very short burst of everheat, without consequences serious enough to find coolant in the oil.
    What I would fear is that the coolant dump was so fast that the temperature probes (both the one for the gauge and the one for the alarm) remained dry before even sensing the coolant temperature increase.
    And in this scenario, by the time the alarm goes off and the temp gauge show a higher temp, it's actually the whole engine block that is overheating rather than "only" the coolant, if you see what I mean.
    Anyway, involving an MTU specialist is certainly the best course of action.
    I for one would be curious to hear his opinion, if you don't mind keeping us updated!
    In the meantime, all the very best for his findings.
  15. DOCKMASTER
    Ketchikan, Alaska
    Do your engines not have low coolant level alarm? If heater ruptured and dumped coolant, why didn’t the low level alarm alert you to a problem?
  16. dennismc
    dennismc Senior Member
    Vancouver BC
    I believe the reason for wanting the heaters off when running is the possibility of low coolant and/ or air entrainment causing hot spots on the heater element and thus they give up working or "worse'?
  17. Capt J
    On MTU 183's they don't. If you ever snap the belts on a 183 at cruise rpm's. The engine will overheat and grenade before the coolant temp alarms ever go off. It was one huge inherent known flaw with them.
    CaptPKilbride likes this.
  18. mapism
    Sardinia
    Correct.
    They fitted a bronze raw water pump which runs forever and never needs an impeller replacement, but God only knows what they were thinking when they made it belt driven.
    MAN engines based on the very same block have a more basic rubber impeller pump, but gear driven.
  19. CTdave
  20. DOCKMASTER
    Ketchikan, Alaska
    I’m still interested to hear if these engines have a low coolant level alarm and why that didn’t alert to a problem?
