Click for Burger Click for JetForums Click for Glendinning Click for Ocean Alexander Click for YF Listing Service
Bleeding air from hydraulic line
Discussion in 'Hatteras Yacht' started by Cooter Brown, Oct 23, 2019.
  1. Cooter Brown
    Cooter Brown New Member
    Blew hydraulic lines on steering. Repaired lines. Now I have 2 station. One in the tuna tower and one at the lower helm on my 1998 Hatteras 43Express. What do I have to do to get air out of both systems?
  2. Cooter Brown
    Hey Capt Ralph. Good to hear from you. Just seems like every time I think I've got everything ship shape something else goes array. Oh well it keeps me busy and I've got plenty good bourbon. Just can't crawl those tight places anymore. I've got an air compressor and tools. But I'm thinking 15 lbs air pressure???
  3. Capt Ralph
    Oh wait.... steering system NOT clutch and throttles.
    Scratch all above.
    For the steering system go to the Sea Star web site and find the instructions to bleed your hynautic steering system. If you can't find it, I'll light up my old server and get it for you.
    Got to West marine and pick up 2 or 3 qts of hynautic steering fluid.
    An air compressor with chuck will help but you will need up to 25PSI here.
    It's a boat. Your never on top of her.
    She just lets you feel good up there some times.
  5. Capt Ralph
    I know about reaching into places and getting stuck. That's when that helper comes in.
    Or if he (she?) is skinnier, he (she) can crawl in there.
    If it's a she, I'll be rite over to help,,,,:cool::cool::cool:
  7. Capt Ralph
    Hammond???
    I got friends near. Some just by you last week.
  8. Cooter Brown
    Good morning Capt. Have all the tools, compressor and all. This gal has a booster pump located near the rudder stock on the port side. I'll trace these lines down and find the oil reservoir. I'll fill the tank up and pressure up the line. 25lbs pressure? Guess I should do one station at a time. Hopefully it doesn't blow oil every where.
  9. Cooter Brown
    I keep the Cooter Brown over in Madisonville. Fresh water harbor.
  10. Capt Ralph
    Booster pump? Electric?
    What brand of steering?
    I assumed a Hynautic system.
  11. Capt Ralph
    Boat owners from Covington have adopted me.
    They have a large band of children and grand kids everywhere.
    I can't keep track of all the names.
  12. Cooter Brown
    It is a hynautic and its electric dc. Pretty sure is 12v.
  13. Capt Ralph
    I'm not sure about that model. You should still have a valve block before the cylinder. There are 2 screw valves you may need to open.
    You really may have to find the correct model and download the manual.
    Calling Sea Star direct may help if your like me, slow on a computer.
  14. Pascal
    The sea star website has a bunch of manuals online.
    Usually you pressurize the tank to 30/35 psi and then turn the upper helm SLOWLY till you get a stop. Then turn the otherway SLOWLY till you reach the other stop.
  15. PacBlue
    PacBlue Senior Member
    Dana Point, Ca
  16. Cooter Brown
    Good morning shipmates. I do have the the Hynautic manual with the right configuration. This weekend I'll have a little help with me. So maybe we can get this thing figured out. Interesting note that when the steering hose ruptured the rudders were in a straight line position. Because the Cooter is a twin screw, I was able to steer the boat in 4ft slop. Throttle back on the port to turn to port, throttle back to turn to starboard. Did that for 80 miles. Interesting trip. It was good to get back to the harbor.
  17. Capt J
    Try cracking the lines on the back side of the tower station. Usually if the boat is sitting a few days the air goes up to the highest station.
  18. Cooter Brown
    Does anyone know the location of the steering oil reservoir on this 1998 Hat 43ft Express? I crawled the engine room, followed lines and couldn't find it. It must be hidden!
  19. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    usually it under the lowest helm. under the dash, in a cabinet etc..
