Click for Ocean Alexander Click for Abeking Click for Westport Click for Delta Click for YF Listing Service
Best route Jax FL to ST Thomas
Discussion in 'Marinas & Waypoints' started by BMS, May 7, 2009.
  1. BMS
    BMS Senior Member
    Savannah GA
    Best route and recommended stops???
    Thanks..... leaving next week
  2. CapLady
    CapLady Senior Member
    Back in Ft. Lauderdale!
    Powerboat or sail and what size? Makes a difference.
  3. BMS
    BMS Senior Member
    Savannah GA
    40' power
    I've done the trip a few times, but need your vessel speed and range between fuel stops to advise you. Size of vessel would help as well.
    In a powerboat with a good range and speed, the best way would be to come down the east coast to WPB or even ft. laud, cross the gulfstream to just south of Bimini (easy Stop), go across the bank and cut through the tongue and then down to Nassau (easy stop), follow the inside of the exumas and pop out Galliot Cut and run down to Long Island, from there over to Seller's Cut in providenciales, then down to Ocean World, DR. From there across to San Juan Puerto Rico, then east to St. Thomas and down the island chain to st. martin.
    Anyways, some good stops are Bimini/cat cay, Chub Cay, Nassau, Sampson Cay (exumas), Long Island or Great Exuma (Long islands easier since they closed the marina on the east side of Great Exuma, Green Turtle in Providenciales, Ocean World, San Juan has two good marinas, etc.
  5. BMS
    BMS Senior Member
    Savannah GA
    Boat is 35' power cruising speed around 30 knots and holds 330 gallons of fuel... Thanks ladies and gents
  6. CapLady
    Savannah to St, Augustine, FL, City dock at St. Aug. face dock fuel. It’s a short first run, good for seeing how the boat runs and verify fuel burn.
    St.Aug. to Ft. Lauderdale. If not enough fuel to get to Lauderdale nonstop, Ft. Pierce is a good stop just inside the inlet to the port side is the Pelican Yacht Club. It is a private club but they let you come in for fuel and an overnight, call ahead: docks,772-464-1734. Nice easy in and out to the ocean with a modest draft. Also their restaurant lets you in as a guest if you overnight. Their Wed. night buffet is one of the best I have ever experienced.
    On to Ft. Lauderdale. Lauderdale Marina to the port side just inside the 17th street bridge is the quickest, face dock fuel.
    Lauderdale to Nassau: From Lauderdale, pass just north of Bimini near north rock, then across the banks to northwest channel in to the tongue of the ocean then on to Nassau. If you need fuel it’s an easy stop in to Chub Cay but you’ll have to clear in to the Bahamas there, no biggie, just takes more time. At Nassau there are two fuel docks easy to use, between the bridges port side, and past the bridges, to starboard. Watch the shallows.
    Nassau to Long Island. Go through to the deep sea at Highborne Cay. You can stop overnight at Highborne Cay marina if you want. It’s a nice little spot. Then on to Flying Fish marina on Long Island. http://www.flyingfish-marina.com/
    Flying Fish Marina to Turtle Cove Marina at Provodenciales, Turks an Caicos : http://www.tcmarina.com . Call the marina when you are a ways outside and they will send a small boat out to guide you in, use it, they are happy to do it.
    Provo to the Ocean World Marina, Puerto Plata, Dominican Republic, http://www.oceanworld.net/index.cfm?organization_id=107&section_id=1543
    From Puerto Plata you have a few choices, north of Puerto Rico or south, Either way with a 40’ power boat I think your fuel might be somewhat limited. Because of that I’d go around the east coast of the D.R. to the Punta Cana Marina. http://www.puntacana.com/dining-recreation/the-marina/marina-services
    Then get a reasonable weather window, (the Mona Passage can be sporty) and on to San Juan, about 145 miles over the north coast of PR. Then it’s a pretty easy run to St. Thomas. You might want to make a stop at the islands around Culebra just east of PR, its beautiful there.
    Have a great trip!
  7. K1W1
    Great words there.
    Maybe you should write a cruising guide while you are in between jobs!
  8. BMS
    BMS Senior Member
    Savannah GA
    Capt Lady that was some awesome advice!!!!! Thanks for all the help hopefully I can return the favor one day.
  9. CapLady
  10. YachtForums
    Nice post LadyCap. :)
  11. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Just be aware that once you get to Provo you can get stuck there for days because of weather out of or to the east. Even if it's fairly calm in Provo.
    Also be aware Ocean World can become unusable in northernly winds and swells.
    You might even look at going on the south side of PR if there is weather from the north.
    You also might want to take a look at "Gentleman's Guide to Passages South"
    by Bruce Sant. While it's designed for sailboats and trawlers it has very good cruising advice and weather information in it.
  12. BMS
    BMS Senior Member
    Savannah GA
    Thanks to all of your replies! I am new to the industry and to this site all of the posts I have read have been extremly interesting and helpful. If any of you come through VA, NC, SC, or GA please send me a message and hopefully I can return the favors and give a piece of advice.
    Scott
  13. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    +1
    I agree
  14. ychtcptn
    ychtcptn Senior Member
    Lighthouse Point, FL
    Along time ago I brought a 39' Hatteras S/F from NC to BVI. One bit of advice to add, is think about running at night from South Caicos to DR and again from DR to San Juan. We found that the winds were alot less at night and once the sun came up the winds would pick up. Our route was-
    Ft. Lauderdale-Nassau-Long Island-Provo(Caicos Marina & Shipyard)-South Caicos-Samana DR-San Juan- Tortola
    Good luck, Oh yeah the best way would be ship it on Dockwise:D
    PS- I just read Caplady, and her advice is spot on, mine differs in Provo and DR. My thoughts on
    Provo- the bank side is a bit more on a direct route and you will not get caught by wx inside the reef, although it is a little more isolated. We then made a short slow hop to South Caicos and left at midnight for DR (can't leave Turtle at night).
    Samana- was a pretty rough stop with 3rd world customs and fuel by truck, we were stern to a commercial pier with a local guy as a guard, I think today stopping at Ocean World might be better, but Samana is closer to SJ.
