Click for Perko Click for Ocean Alexander Click for Glendinning Click for Abeking Click for YF Listing Service
Bertram 42
Discussion in 'Bertram Yacht' started by Thistledew, Aug 2, 2009.
  1. Thistledew
    Thistledew New Member
    Western Canada
    I am need of assistance. I am wanting to put a 1982 42 Bertram S/F into commercial operation up here in Canada. To complete the process I need to submit a set of line drawings(hydrostatic etc.) to Transport Canada. Up to this point all my attempts to locate a set have failed. If anyone knows how I could obtain a set I would be more than grateful. Thanks in advance
    Dave
  2. Jorge Lang
    Jorge Lang Senior Member
    I would give Bertram a call and ask for their engineering department. They may have the drawings available.
  3. dennismc
    dennismc Senior Member
    Vancouver BC
    Depending on who your inspector is, you may have to do a stability report along with the book, will require an Architect, also depending on the insulation behind walls etc, it may have to be all removed. You will need an isolation transformer and of course a meggar test, be prepared for major headaches and lots of B.S. as you are over the 15 ton limit , different regs apply.
  4. Thistledew
    Western Canada
    Thanks for the help. I understand that I have a lot of hoops to jump through and they make it unfeasable to start a new commercial venture , attitude dependent. I have contacted Bertram but went through the service Dept. and only got a floor plan off a brochure. Will try again. Again Thanks in advance.
    Dave
  5. dennismc
    Vancouver BC
    I had looked at a Bertram down there and requested some lines plans, but, a brochure copy is all I got. Failing that, you are into big bucks.
  6. Thistledew
    Western Canada
    Thanks for the heads up . Any idea of the cost for an architect to do the drawings.
    Dave
  7. Thistledew
    Western Canada
    THANKS DENNISMC . wILL TRY YOUR SOURCE.
