Click for Furuno Click for Abeking Click for Delta Click for Mulder Click for Westport
Batteries
Discussion in 'Technical Discussion' started by 1000 islands, Jul 16, 2015.
  1. 1000 islands
    1000 islands Member
    Ivy Lea
    I have had a 8D battery installed by a marina to run my fridge only and it just is not doing what I need.
    It dies after about 36 hours.
    I have now been told, by a boater, that the battery I have is not a good house battery and only adequate, at best as a starting battery.
    The battery is a Quick Silver model 908d.
    What model of battery should I have ?
    And should I have opted for golf cart batteries?
    The problem I have is there is very little room in my engine room....1989 Carver 3607 Aft cabin with twin 7.4L
    This has cost me a small fortune so far and I want it to end.
    Thanks for all advise
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Not sure about a Quicksilver battery, but an 8D should give you about 3 days on a 12v fridge (unless the kids are leaving the door open).:(
    Deep cycle/golf cart batts are your friend, invest in one bloody good one and you should be fine. Make sure the charger is set-up for wet batts, not gels. You can't mix'em.
  3. Capt Ralph
    36 hours and no charging? What are you expecting?
    The 90 8D (Deka commercial), delivers very well as a 8D4, flooded cell battery. Heck of a cranker @ 1400 CCAs. Real nice reserve.
    A real good AGM in a 8D sized case may, MAY give you another day at twice the price. Fancy golf Cart batteries a few more hours over that.
    Such weight and you are not recharging it? Oh, already asked that...
    Learn how to drink cheap warm rum and keep the wife & kids out of da ice box. Da rum helps when the crews lips start flapping.;)
  4. Good Spirit
    Good Spirit Member
    I had the same model Carver and installed 4 Trojan golf cart batteries to run my house system. I also installed a 3000 watt inverter with a 100 amp charger. I put two batteries back against the wall to the aft cabin and two just beside the transmissions . I also used two deep cycle batteries for starting engines and genset.
  5. Sea Gull
    Sea Gull Member
    CT
    How about running the generator enough to keep up with the load demand on the battery?
  6. Norseman
    Norseman Senior Member
    Not a Carver, but I used two 75 satt solar panels to charge 4 golf cart batteries which ran a "Cool Blue" fridge and freezer system. With sunny weather I could sit for anchor indefinetly without starting the main engine to charge the batteries.
    -18 C in the freezer and hard ice cream in the Exumas, life is good...(cold beer was also included)
    Find out what the daily load on your fridge is? (Amp hours)
    Then you will know what kind of battery you need and how often to charge it.
    Also keep in mind to never discharge a deep cycle battery below 50% capacity, it will shorten it's life considerably.
    (I used 70% as my target, the bank lasted 6 years)
    Keeping the batteries in the engine compartment is probably not a good idea,
  7. 1000 islands
    1000 islands Member
    Ivy Lea
  8. Norseman
    Heat and vibration.
    The recommended location is in a clean, cool and dry.
  9. Capt Ralph
    And ventilated if they are flooded cells.
  10. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Are you saying that 8D dies after 36 hours and you haven't re-charged during that period? While you're not on shorepower, yes?
    Many 8Ds will give you about 245 amp-hours, discharging to 50% means 120-ish available before recharging... so how many amps does that fridge need? Is the fridge running on DC, or is it running on AC from an inverter? What else is running off that battery, if anything?
    Are you drawing that battery down to near zero state-of-charge? Anything below 12.0V? How often do you recharge?
    FWIW, we have 300 Ah banks (150-ish usable) with a relatively economical fridge on each, and I have to recharge 2x/day.
    I've read most 8Ds are not deep cycle batteries, even when the label says it is. Dunno anything about yours, but that's one of the reason some folks choose golf cart batteries, which are said to be true deep cycle. Four of those would give you more like 440 Ah at 12V, and might easily fit.
    -Chris
  11. RT46
    RT46 Senior Member
    are you saying your 8D will run your fridge for 36 hours and then die?
    that is a long time.
    I have an 8D house battery and only use the inverter when I turn off the generator over night for a few hours.
    Depending on how cold the fridge is and how many AC lights I leave on there is usually enough juice in the 8D until I start the genny in the morning.
    BTW, here is a trick I learned to get more out of the battery:
    I turn the fridge all the way up and leave it on high.
    The fridge use a lot of juice cycling the compressor on than it does running constantly.
    I have a regular AC fridge, I don't know much about the AC/DC fridges.
    I shut the cockpit freezer and usually leave the ice maker on.
  12. 1000 islands
    1000 islands Member
    Ivy Lea
    The seller of the fridge, Nova Kool, says that with an 8D dedicated to just the fridge, which mine is, it should run for 3 days minimum. That's 72 hours.... more than twice what I'm getting.
    And yes I've also read that 6d's are not true deep cycle, in fact I've come to discover that they are better as a starting battery.
    I'm now considering 2 things,
    One is to just dump the 8d and replace with 6volt batteries and the other is to chage the 8d over to a starting battery for both engines and then add 6volt batteries as house batteries.
    Or the third option which is becoming a very populare one around here is to just go out and add solar panels and the problem is solved forever.
    But wow are they costly !
  13. ranger58sb
    Chesapeake Bay, USA
    Which model NovaKool? And in what kind of exterior/interior ambient temps? Three days if outside and inside temps are in the 60s is likely different than if outside temps are in the 90s and inside temps are in the 80s.
    Ours are both NovaKool, but I've never tried to run then for days without recharging. And we have other loads on the batteries, too...
    As to alternatives, GCs would probably be good, but why not just recharge more often?
    -Chris
  14. Capt Ralph
    I'm may still be missing some environmental data here but I am assuming;
    you don't have shore power available
    You don't have a gen-set
    You have lots of money
    And a strong back for lifting batteries about.
    Oh, I would not buy a used car from your NovaCool guy either.
  15. ranger58sb
    Chesapeake Bay, USA
    NovaKool amp draw chart. Note values are based on 75-degree temps, after the unit has reached desired internal temps.
    http://www.novakool.com/documents/ampdrawperunit_001.pdf
    A bigger unit -- e.g., RFU9009 -- would draw 234 amps in a 36-hour period. That'll kill an 8D...
    Even smaller units that draw 4.4 amps would be using ~158 amps in a 36-hour period, drawing an 8D down to about 35% SOC.
    -Chris
  16. Capt J
    Why not just get a Honda 2k portable generator and a big battery charger and just run the generator for 3-5 hours every couple of days and charge the battery?
  17. 1000 islands
    1000 islands Member
    Ivy Lea
    Generators of any kind, on board or portable are not allowed on most of the docks in the 1000 Islands.
    I have both a 2k Honda and on board generators.
    The Nova Kool I have is the RFU 9000 12 volt.
    I researched the various brands/options and felt that the Nova Kool RFU 9000 was the best bang for the buck in my situation.
    And to answer rcrapps, I have a genset, little money, a bad back and no shore power except at home dock.
  18. Capt Ralph
    And, we have just learned why you are going thru these back pains.
  19. ranger58sb
    Chesapeake Bay, USA
    I don't see an RFU 9000 on that link, but I'd guess then maybe their RFU 9009 draws about the same amount of current. (Your manual will say.)
    If it's 6.5, and the 8D provides around 245 Ah, the math says you'll reach 50% SOC (122.5 Ah) at about 19 hours.
    For comparison, 4x GC2 golf cart batteries (slightly larger footprint than one 8D, not as large as two 8Ds) would give you about 440 Ah, and about 220 Ah to 50% SOC, at about 34 hours.
    I don't necessarily see "three days" anywhere in there, although that can be influenced by ambient temperatures and your climate may be an example of that.
    There might be some Lithium (LiFePO4) solutions, but at serious expense and apparently with a learning curve. But maybe solar is more mainstream, assuming you have the real estate (and the wallet).
    -Chris
  20. Capt J
    He might not have enough sunlight up there to make solar a viable option. If you're anchored, I don't see why a little portable generator cannot be run for a few hours everyday with a large battery charger, or just start the main engine and run it a little while.
