Click for Abeking Click for Westport Click for Cross Click for Perko Click for Burger
Bacteria/fungus in fuel tank 68’ lazzara
Discussion in 'Lazzara Yacht' started by Jennifer Anne, Aug 4, 2019.
  1. Jennifer Anne
    Jennifer Anne New Member
    w FL
    weve had the strainers cleaned and the fuel polished one day.
    How can we get this junk out of system once and for all?
    Thank you!
  2. Pascal
    Polishing the fuel should help assuming their fuel pick up was all the way at the bottom to get the water out.
    Then burn the fuel keeping a close eye on the racors. Assuming Lazzara installed twin racors for each engine make sure you run one at a time so you always have one ready to go. Many people run both at the same times which means they both get dirty and when you notice it s too late
  3. Jennifer Anne
    w FL
    Thank you!
  4. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Sometimes the only option is to cut a hole in the top of the tanks and hand clean them. The bacteria just loves to sit in all the corners.
    Following that, a strict regimental dose of fuel treatment should follow.
  5. Capt Ralph
    Are you using the boat any? Or dock Queen?
