Click for Westport Click for Westport Click for Abeking Click for Walker Click for Northern Lights
Azimut power windows
Discussion in 'Azimut Yacht' started by Ateve, Sep 2, 2022.
  1. Ateve
    Ateve New Member
    Vancouver
    Does anyone know where I can purchase port and starboard power windows for my 2005 Azimut 62
    From an Azimut dealer. That's the only place I know of to order them.
  3. Ateve
    Ateve New Member
    Vancouver
    Thank you , but they no long stock these parts and was hoping to find the original supplier of these windows
  4. captholli
    captholli Senior Member
    In The Bilge
    The glass manufacturer 's name should be etched into a corner of the glass somewhere. CMR used to make a lot of glass and stainless portlights for Italian yachts 20 yrs. ago but that was before designers & builders went nuts with compound curved panes in coach roofs and hull sides.
  5. Capt Ralph
    The glass or the electric power option has failed?
    There are glass shops that can reproduce the glass.
    Re-inventing the wheel may be required to fix a motor problem. Mfg name may be on this hardware.
    No longer stocking parts does not mean they do not know who made it or who higher up the scrotum pole you can contact.
    If you do find somebody that wants to help you, get the mfg, order and job numbers. The mfg can go back and make you one or two.
  6. Sailor Fred
    Sailor Fred New Member
    Rhode Island
    Was able to order new motor from marine max but on my 60 problem is with gears not motor
