Hi, i have a problem only with one motor, in the ignition key not receive 24v in one only ignition key, port. If i change the connector with 24v from starboard and made the check of the motor but send me an error in gauge cat. Anybody can helpme? I check all fuse, all are ok. Thanks!!
I remember Azimut had a habit of putting glass fuses inside one of the (usually grey) breaker boxes in the engine room. Also CATS generally have a couple of fuses on the motor as well, a red 1" push in fuse and usually 2 other fuses. Check there.
Oh yea, I remember the thread where the fuse was hidden in an ER box. Cats do have that breaker that does pop also. Put the two together (Cats & Muts) and anything is possibly a failure point. Take a breath, relax, remember; It's your Mut.
