Click for Cross Click for Westport Click for Burger Click for JetForums Click for Northern Lights
Auto Pilot hydraulic pump wiring diagram
Discussion in 'Electronics' started by Wakeywoo, Mar 2, 2018.
  1. Wakeywoo
    Wakeywoo New Member
    Hello, I am struggling, I ha e bought a 2005 Azimut 50 and the raymarine Autopilot computer had been removed.
    I am trying to fit another one, I have found the wiring for the compass and the rudder indicator and the solenoids but cannot find any wiring for the hydraulic pump. I am not sure if the thing runs all the time or just when required. Any suggestions would be appreciated
    Have you found the pump? What solenoids?
    If is a high current pump, the solenoids may drive it.
  3. Wakeywoo
    Wakeywoo New Member
    Thank you for taking an interest, it turns out that it a constant running pump which gets its feed from the port engine ignition. The pump had a bizarre wiring terminal fault which was throwing me off but I got there ( more luck than judgement). I am still intrigued to find where the relay is but for now at least I know how to wire up the auto pilot. Thanks again.
    I still have my Robertson constant running pump on our old Bert.
    Kept it while upgrading from the Rob-1000 to AP-28.
    I luv it. Nothing faster.
    Usually a constant runner draws a bit of current. Nice fat wires from the battery controlled by the pilot thru a nice power relay.
    Maybe your port ignition switch is turning on that relay (somewhere).
    I would hate to think the pump motor is running while not in use.
  5. Wakeywoo
    Wakeywoo New Member
    Yep it is controlled by the ignition circuit, I was kind of hoping it was brought into play when the solenoids were activated but that is not the case. At least I know now that if the engines are not running the motor shuts down.
