Click for Abeking Click for Walker Click for Furuno Click for JetForums Click for Northern Lights
Aqua-Box Multi Stage Pressure Pump
Discussion in 'Technical Discussion' started by Gödeke, Jul 19, 2022.
  1. Gödeke
    Gödeke New Member
    USA
    Anyone has experience with the Headhunter fresh water pumps Aqua- Box multi stage pressure pump?
  2. captholli
    captholli Senior Member
    In The Bilge
    I know a few active chief engineer friends that have the single and double units installed & they have nothing negative to say about the Aqua Box pumps from Headhunter plus you don't see any of these units on the secondhand / used market so they must perform up to standards or they'd be available on the used mkt like the Mach 5 is. That being said, you're talking about $4,000 dollars + for the single and close to $10,000 for the twin multistage pressure pump that've been out in the marketplace for five years now that really targeted the mega yacht crowd of 50 meters and over and I understand that Headhunter makes a smaller version or "mini Aqua Box" for smaller vessels but have no firsthand nor secondhand info /knowledge of the mini. For that kind of scratch, you might as well upgrade to a Spec pump @$12,000 dollars and be done with it. ;)
  3. captholli
    In The Bilge
    Sorry for my typo to cause head scratching as to just what the heck I was referring to as a "Spec" pump and what that might be? Speck Pumpen is a German pump manufacturer of many different types of pumps for many different industries, but their linier piston pumps have been the gold standard freshwater pressure pumps specified on Feadship's builds for the last 40 yrs. You can find the Speck PM-30 on quite a few northern European builds unless otherwise specified as they're virtually bulletproof piston pumps that will run for thousands of hours before being easily serviced /rebuilt in house. They're also the gold standard price wise.
  4. S J Meyer
    S J Meyer New Member
    Isle of Hope, GA
    The Aqua-Box is a DAB E.SYBOX pump. Great pumps, I use one for my home and one on the boat.
  5. relax
    relax New Member
    Pensacola Florida
    What model did you put on your boat?
    I have 3 heads and showers.
    I currently have a nach 5 pump
    And I want to replace it.
    The mini 3 says it’s a booster pump.
    Will the mini 3 self prime?
    Is it a suitable replacement for a Mach 5?
