Click for Westport Click for Westport Click for Walker Click for Northern Lights Click for Delta
Any info on a 1978 benetti 100’ boat in Los Angeles ?
Discussion in 'Benetti Yacht' started by Matt46post, May 4, 2021.
  1. Matt46post
    Matt46post Senior Member
    El dorado hills california
    Anybody have any info on a 100’ forsale in Los Angeles , it’s on eBay and looks to have started life as a 88’ 1979 , it appears to have a steel hull aluminum super structure and was in a boat yard for 5 years and had a lot of work done to it but never finished, looks like it could be a nice project
    Or it could be a money pit. Back in the 1990's a lot of boats were being extended. Some worked out better than others. 25% is quite an extension.
  3. leeky
    leeky Senior Member
    Florida
    I calculate 13.6%.
  4. MBevins
    MBevins Senior Member
    Windsor On. Canada
    I was thinking the same thing.:)
  5. NYCAP123
    Correct. My mistake.
  6. Matt46post
    I don’t think the extension is the issue , just wondering if anybody saw the boat during the 5 years on the hard going thru a refit and redesign of the hull and super structure
  7. MBevins
    Windsor On. Canada
    Just busting your chops. :)
    It's a Benetti. That is ALL you need to know, RUN for the hills unless you're an ABCY certified marine electrician and 5'5 and 150 lbs. Not to mention it's about $250k or more to rebuild those old, smoky, 16v detroits, so you might as well plan on repowering it right off the bat or it won't ever be worth anything as far as resale goes.
  9. Matt46post
    Really $250k to rebuild a pair of 16v Detroit’s , I don’t think so probably more like $60k
  10. Oscarvan
    Oscarvan Senior Member
    Chesapeake Bay
    At $3000 a jug I'm at 100K And "while we're in there we may as well".... But yes, 250K is a little high drama.
  11. Capt J
    Try accessing the bottom end in that boat. The length of the crankshaft is also an issue. While you're there, the blocks should be seperated and new pins installed. 16's add a lot to rebuild, but call your local dealer and ask them what it costs.
  12. costalive
    costalive Member
    newport beach
    Maybe I can help I can’t find the listing can you post the link
