Click for Northern Lights Click for Mulder Click for Burger Click for Glendinning Click for Perko
Antifouling for Aluminium Hulls
Discussion in 'Technical Discussion' started by Manessa, Mar 9, 2017.
  1. Manessa
    Manessa New Member
    I am trying to get some good advise with regard to the best antifouling to use on 56 ft Aluminium yacht
  3. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    The Seajet Emperor I meantioned on that thread is made for ally hulls.
  4. Manessa
    Manessa New Member
    The yacht is in New Zealand sailing and motoring speed 7 to 8 knots. I have previously used Jontun. Would like to get information on other options
  5. ESSRTEE8
    ESSRTEE8 Member
    56 POST in Monmouth Beach NJ
    Is your yacht barrier coated?
  6. JWY
    JWY Senior Member
    Are you referring to Jotun? What didn't you like about it? Or what are you looking to do differently?
  7. dikikh.dm
    dikikh.dm New Member
    Malta
    Hello everyone,
    I'm reconditioning the Seachest boxes for cooling water intake, so they are always full of sea water. The material is aluminium. My plan is to clean it from old paint as good as I can,sand the bare aluminium and then apply etching primer and couple of coats of the same antifouling, which we use for the hull, Nubian 50. What do you think about that? Shall I use something between etching primer and antifouling?
    Thanks and regards
  8. ESSRTEE8
    ESSRTEE8 Member
    Wouldn't you be better off with some kind of barrier coating to the sea chest?
  9. dikikh.dm
    Malta
    Do you mean something like Epoxy West System barrier coating?
  10. dennismc
    dennismc Senior Member
    Vancouver BC
    Be sure the aluminum is totally free of scratches. pitting and imperfections and old coatings, otherwise what you put on will come off in places, your barrier coat should be minimum 12mills thickness before any copper based paint goes on.
  11. ESSRTEE8
    ESSRTEE8 Member
    Interprotect barrier coat from Interlux/Azko Nobel maybe.
