Click for CL Yachts Click for Glendinning Click for Burger Click for Walker Click for Burger
Alloy's New 41-meter "Como"
Discussion in 'Alloy Yacht' started by YachtForum, Nov 23, 2006.
  1. The 41m (134ft) motoryacht "Como", was launched on 12th November 2006 at Alloy Yachts, New Zealand. The yacht commenced construction in March 2005.
    Managing Director Tony Hambrook commented that the Dubois Naval Architect designed Como is the largest motoryacht built at Alloy Yachts. She has an 8.5m (27.9ft) beam, draft of 1.9m (6.2ft) and displaces 214 tonnes. The interior design is by Redman Whiteley Dixon.
    The main accommodation on the lower deck has two double guest cabins and two twin cabins, all with ensuites. The crew quarters have a double Captains cabin and two twin cabins all with ensuites. This area also includes the galley, crew mess and separate laundry.
    The engine room houses two Caterpillar C30 1550hp engines. Two Northern Lights 55kw generators are built-in together with one 55kw Mastervolt shore power converter. The 6.0m tender is stored in the lazarette and is launched through a watertight door on the port side. The 4.3m crew tender is stored on the foredeck with a davit for launching. A docking station is fitted on the starboard side of the aft cockpit.
    Como carries 36000 litres of fuel with a cruising speed of 16 knots and a sprint speed of 17.5 knots. Her range at 10 knots is 4000nm. There are two water makers each producing 4500 litres per day.
    The main deck has an aft cockpit and an alfresco dining area with a sliding sunscreen. Forward is the main saloon with bar aft and separate dining area with seating for up to 10 guests. Large wrap around windows provide expansive views.
    Ahead of the dining area and on a half level above the main deck is the bridge. A stairway leads from here up to the flybridge which can also be accessed from the aft cockpit. This expansive area includes a bar, barbecue and dining for up to twelve guests under a fixed sun awning. There is also extensive built in seating and a large sunpad.
    Forward of the guest lobby on the starboard side of the main deck is the owner’s lobby leading to the master cabin with large walk in wardrobe and two ensuites with central shower. On the port side of the master suite is a lounge area and owner’s study.
    The yacht has a Naiad stabilizer system plus bow and stern thrusters and the latest Alloy Yachts designed and built passerelle. Como is built to Lloyds classification and complies with the Large Yacht Code. She is flagged in the Cayman Islands.
    For further information contact:
    Alloy Yachts
    Phone: (64 274) 949799
    Website: www.alloyyachts.com
