Click for CL Yachts 99X Click for Burger Click for Abeking Click for Westport Click for Glendinning
Alloy Yachts Sloop - Paraiso
Discussion in 'Alloy Yacht' started by YachtForums, Apr 20, 2004.
    Paraiso 33m Sloop...
    A 32.97m (108ft) sloop from Fontaine Design Group began construction at Alloy Yachts in November 2002. She will be named Paraiso and is for an international owner. The aluminium sloop has a beam of 8.0m (26.27ft) and has a centreboard to allow the yacht to be moored in shallow water.
    She will draw 2.15m (7.05ft) with her centrebord raised and 7.0m (23ft) with the board down. She will be rigged with a carbon fibre mast and in boom furling. Eight Alloy Yachts designed captive winches will handle the sails. Two 300hp Lugger 6108 A2 engines will be fitted with Hundested propellers. There are two Northern Lights generators each 33kw. Range is 1800nm at 11.5knts. Davits will be fitted aft to handle the tender.
    Paraiso well into construction, November 2003
    The interior will have walnut raised and fielded panels. The pilothouse deck head will have painted grooved timber. The sloop has a deck saloon with bar and lounging area leading up to the pilothouse with inside dining. Stairs lead below to the saloon with formal dining to starboard, and aft to the two guest cabins with ensuites. The owner's stateroom aft has a dressing room, office and access to the cockpit. Galley, crew mess and accommodation for four crew are forward.
