Click for CL Yachts Click for Abeking Click for Glendinning Click for Ocean Alexander Click for YF Listing Service
Allison Transmisson question.
Discussion in 'Technical Discussion' started by mysue, Dec 13, 2011.
  1. mysue
    mysue Guest
    I have an 1983 54' Bertram with 800hp detroit 12v71's and Allison Tranny's. I have two questions. Can the filters be cleaned or are they a replaceable cartridge? Also, How do you pump the oil out for an oil change. Any help is appreciated.
  2. Freespool
    Freespool New Member
    Kemah, Texas
    Most likely a Twin Disc MG514. The filter is a replacement item. There should be a tag that tells you the model and BOM of the gear. The filters are different for an A,B, or C model gear. Most 54's had a quick connect oil change system.
