Click for Walker Click for Burger Click for Glendinning Click for Burger Click for Ocean Alexander
Aftercooler C30
Discussion in 'Engines' started by Yves Lambert, May 30, 2019.
  1. Yves Lambert
    Yves Lambert New Member
    hallandale beach, FL
    I have 2 CAT C30's in my Hatteras 80 with 2200 hrs
    My aftercoolers need to be cleaned and probably changed. I was told that there is a CAT upgrade to a new aftercooler model and the expense could be up to 15,000$ per engine.
    Can anyone tell me more about this?
    Yes, the aftercooler design was changed a number of years ago and the old style aren't available. The newer style requires several other parts to retrofit into the older style housing such as the housing cover plate. I was quoted around the same number +/-. I generally use N+G engineering for CAT work. If they're over 6 years old, replace them.
  3. Yves Lambert
    Thank you
