Click for Burger Click for Abeking Click for Furuno Click for Delta Click for Glendinning
adaptation to MCA small craft code MGN 280
Discussion in 'General Yachting Discussion' started by woofwoof, May 29, 2021.
  1. woofwoof
    woofwoof New Member
    sint maarten
    Hi, we're buying a new cat and will not be using it commercially. The boat manufacturer has got the option for adaptation to MCA small craft code MGN 280. My question is if we don't choose this option will a next owner still be able to adapt the boat accordingly without any major costs in case they do want to use it commercially?
  2. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Depending on the cost difference, adding a MCA rating will add greatly to the boat's resale value.
  3. Capt Ralph
    Fish has a great thought.
    However, I always thought these codes helped on work, crew and heavy commercial small craft (under 24M).
    IE; supply or pilot craft.
    You may want to dig deeper into this as it may or may not refer to charter and rec passenger levels as that could always help in your resale.
  4. woofwoof
    woofwoof New Member
    sint maarten
    Thank you for your reply. It is almost US$60,000, is it going to be a lot easier to do while they’re building the boat or would it be an easy enough upgrade later on for that amount spent?
  5. woofwoof
    woofwoof New Member
    sint maarten
    Will do, thank you.
  6. jfm
    jfm New Member
    London/Antibes
    It's a slightly "how long is a piece of string" question because it depends on what is different between the standard build and the mgn280 build. Just as an example, mgn280 may require engine vent closers to make the engine room airtight in a fire, and many boats already have this in their standard spec, and many don't.
    I say "may" because despite the clear terms of mgn280 you see lots of variance between different surveyors (who sign off) about what is needed.
    You should get a list of what the builder does to get from standard spec to mgn280 and see if its good value/retrofittable. A lot of it will be just buying loose stuff (LJs, LRs, loose safety gear).
    I wouldn't code to mgn280; I'd code to Yellow Book. Personal choice (and you do have a free choice, despite many builders/surveyors acting like mgn280 is the only choice). But that's a whole nuther topic.
  7. NYCAP123
    But will you be increasing or decreasing your resale buyer pool. Are there more buyers looking and being willing to pay for the MCA rating, especially as the vessel ages, or more who would rather get the boat cheaper. For some the thought that a boat may have been used commercially could be a turn off.
    jfm likes this.
  8. woofwoof
    woofwoof New Member
    sint maarten
    Thank you JFM, great reply. Will get into the specifics with the builder.
  9. woofwoof
    woofwoof New Member
    sint maarten
    Yes, commercial use is a turn off for me and many others except of course charter businesses. Will likely leave the rating but would still like to know what exactly the builder does for the rating. Thank you for your reply, it was helpful.
  10. Capt Ralph
    Please keep us up on the details as you discover them.
  11. NYCAP123
    There's been a Bluewater down in Miami for decades that was certified for 49. Back in the day a company rep told me one thing was fire retardant resin.
    woofwoof likes this.
  12. woofwoof
    woofwoof New Member
    sint maarten
    Will do, if the builder is ok with that.
