Click for Ocean Alexander Click for Northern Lights Click for Abeking Click for YF Listing Service Click for Abeking
ac problem
Discussion in 'Carver Yacht' started by jerry harmon, Aug 13, 2019.
  1. jerry harmon
    jerry harmon New Member
    hendersonville tn
    Hi guys. I am new kid on the block for yachts, and appreciate your help. I have a 95 carver aft cabin with twin 350 crusaders my ac will work for a while then the screen on the thermostat reads CDL I am pretty sure that is what is was. I am not positive. Both units are doing it. Can anyone suggest anything I can try before looking for a specialist?
  2. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    If both units run off one pump then that would be where I would start since you said both units have the same readout.
    I've never seen a CDL error, usually it's HP, LP or LO AC. Check the pump and check the air conditioning strainer, those usually have to be cleaned often.
  4. Pascal
    Never seen CDL either
    I d check water flow first as this is usually the most common source of issues
  5. Poppa John
    Poppa John New Member
    Naples Florida
    I know you will but, you really need to double check the readout before doing anything.
  6. CSkipR
    CSkipR Member
    Are you familiar where the water exits the boat after it circulates through the ac units? If so, are you getting water flow? If not check for blockage at sea strainer. Check to see if pump is running.
