Click for JetForums Click for Nordhavn Click for Mulder Click for Westport Click for Northern Lights
a little help, please. fish finder 89 santego 27'
Discussion in 'Carver Yacht' started by droops!, May 29, 2010.
  1. droops!
    droops! New Member
    winthrop, ma
    so here we go. my girlfriend's dad has the aforementioned boat. he has put the transducer through the hull, and the wire is patiently waiting in the engine compartment. the mount is all set on the bridge. i'm trying to figure out how to connect point a to point b. i do not see an open chase from behind the fuse panel. so that leads me to assume the only way to fish the wiring is to remove the panel to the left of the sliding door.
    cheers,
    drew
    You could use an existing wire from the bridge. Disconnect it at the bridge, pull it through to the engine room with a chase string. Then just pull it back with your new wire and another chase for the future.
  3. droops!
    droops! New Member
    winthrop, ma
    my only problem with cutting a wire and pulling it through, is that i would almost guarantee that they are zip tied in bundles. if you think that is not a valid thought please let me know. thanks for your input.
  4. NYCAP123
    Wire ties will be accessable. Snip, snip, retie.
