Click for Walker Click for Nordhavn Click for Northern Lights Click for Mulder Click for Mulder
A/C Equipment
Discussion in 'HVAC' started by dennismc, Feb 8, 2018.
  1. dennismc
    dennismc Senior Member
    Vancouver BC
    Any feedback on Marine Air stuff out of Miami ?
    or Mermaid air Ft Myers ?
    Just looking for plus or minus on the actual equipment.
    Thanks.
    Stick with dometic. dometic owns both Marine Air and Cruisair. The other stuff is noisy, doesn't hold up, or just plain junk.
  3. Pascal
    I don't know about that... can't say I find cruisair stuff to be reliable or well built. I had Ocean Breeze remote condenser on my hatt and they were as good as the cruisairs. I eventually redid the whole boat with Flagship Marine chillers and the built quality is better than Cruisair. Everything is solid SS along with simple control system vs expensive proprietary boards.
  4. captholli
    captholli Senior Member
    In The Bilge
    +1 on Flagship. Excellent quality and customer service. Now just convince them to Awl Grip their units because they resist doing this for some unknown reason.
    I have another experience with flagship. The hi pressure sensors had to be manually reset by pressing a push button on the high pressure sensor on the unit, which was a mother to get to and reset all 5 of them. The units were noisier then hell, all 5 of them, because they had no vibration dampening on the units and transmitted the vibration to the part of the boat they were mounted to, (these were package units). They were so noisy it was ridiculous.
    Yes, dometics are pricey, but they work, they work well, and they're quiet.
  6. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    Yes Dometic units are pretty good but their SMXir thermostats are a joke. Had to replace 3 of them in four years and now have another bad one. They get where you cannot change the temperature up or down.
    I have not had this issue at all. Try moving the bad unit to a different room/ac unit. It sounds to me like you have something else going on their. Perhaps the circuit board on the unit is going bad and sending the wrong voltage to the thermostat and frying it.
  8. Capt Ralph
    Seems I'm having a fun time with one SMX/IR system. After changing the operator panel a few times now, the system turns it self on without any buttons pushed. It mostly comes on de-humiditfy mode so it's not a big woo.
    I blame it on an on-board ghost having some fun.
    I have also found the temp senders that sit in the air return path can cause wired panel problems.
  9. CSkipR
    CSkipR Member
    Yes I can switch the good one around to the bad one and do that to lower/raise the temperature. The bad thermostats will turn the unit on just not adjust the temperature. The thermostat issue has happened on both ac units.
