Click for Cross Click for Abeking Click for Perko Click for Walker Click for Burger
89 Carver 4207 aft cabin
Discussion in 'Carver Yacht' started by Brian135, Mar 24, 2020.
  1. Brian135
    Brian135 New Member
    Maple Ridge BC Canada
    My boat is equipped with an Onan MGKUB Genset. I'm trying to locate the fresh water pump to replace the impeller. Does anyone know where it is located..?
  3. Brian135
    Brian135 New Member
    Hi...thanks for this. My genset is equipped with a heat exchanger for salt water use. The pump in the specs you sent is for coolant. I'm pretty sure there is a remote pump that pumps seawater through the heat exchanger and I'm trying to figure out where it's located. Thanks so much for your help.
  4. Capt Cole
    Capt Cole Member
    Pittsburg CA
    If you haven't located the raw water pump yet, just follow the hose from the thru-hull for the genset. It should lead you directly to the pump which will be mounted on the front of the motor and is driven by a belt.
