Click for Mulder Click for Furuno Click for Mulder Click for Perko Click for Walker
82 Viking 44 MY Prop shaft seals
Discussion in 'Props, Shafts & Seals' started by Racerx4772, Jul 25, 2022.
  1. Racerx4772
    Racerx4772 New Member
    New to this boat , How or where do you get to the prop shaft seals and where is the rear bilge pump also ?
    trying to check over new boat to me have a little water coming in and want to get the correct maintained
    done if i have to pull the boat out . Have a some thru hulls that look like they need to be replace also .
  2. MBevins
    MBevins Senior Member
    Windsor On. Canada
    Welcome !
    Rear bilge pump is starboard aft corner, remove bottom drawer, it is remote with a pickup tube.
    As to shaft seals, nothing specific to this boat, shafts are 2" I believe the tubes are 3.5" but don't quote me it's been a while.
  3. Racerx4772
    Awesome , where are the shaft seals ? Id like to see if that's where the water is coming in .
    Thank you !
    Jerry
  4. MBevins
    Windsor On. Canada
    In front of master shower, in the floor if the master closet.
  5. Racerx4772
    Thank you !!
    This stuff is like an Easter egg hunt , forum has been a huge help !
    Jerry
  6. MBevins
    Windsor On. Canada
    The closet also has the shower sump as well, if running seawater electric heads, the pump for the master is between the head door and the corner of the bed.
  7. Racerx4772
    head has a vac system , think the tank is in the engine room . Floor under the head has some rot / 4 head bolts wont completely tighten , going to have to fix that eventually
