Click for Delta Click for Walker Click for Burger Click for Ocean Alexander Click for Mulder
671TI throttle return spring
Discussion in 'Engines' started by Boomer, Nov 8, 2020.
  1. Boomer
    Boomer Senior Member
    Seminole
    Hi everyone..question: the spring on the engine pulls my throttles back on the bridge over after getting up on plane...I had the throttles set pretty stiff and the spring about as loose as I can without it getting sloppy...suggestions? Pretty sure you just cannot remove that spring...lol
  2. mwwhit1
    mwwhit1 Senior Member
    a
  3. Boomer
    Seminole
  4. cleanslate
    cleanslate Senior Member
    Cherry Hill, NJ
    Ka-Boomer ! The spring on the governor end where it hooks onto, came be moved around just a bit up or down. It doesn't move much, nor does it need to to get the pull just right. You can move it around with the spring still on , btw. You need to have tension on that booster spring. When you get it right you will see the difference. You should have a nice smooth stead range through the travel of the throttle.
  5. Boomer
    Seminole
    Thanks...at this point, it looks like a winter job...getting ready for haul out for bottom job and some work
  6. cleanslate
    Cherry Hill, NJ
    It’s pretty easy job , but with boats as always nothing is easy.... and other priorities take precedence.
    You can do it at the dock , I assume you know that.
    Has to be with the motor running.
    that’ll be great getting the bottom done you should pick up a lot of performance with the boat after having that done.
    Mine needs to have the bottom done also.
  7. Boomer
    Seminole
  8. Boomer
    Seminole
    Putting new nibral wheels on..24x24 4 blade to increase performance and then go from there...new swim platform also!
