Click for Abeking Click for Burger Click for Ocean Alexander Click for Cross Click for Nordhavn
'67 '37 Riviera
Discussion in 'Chris Craft Roamer Yacht' started by pugetsound37, Sep 19, 2006.
  1. pugetsound37
    pugetsound37 New Member
    Seattle
    Hello, all. I own hull number two (RXA 37 3002 R) and am wondering what folks consider state of the art in terms of bottom paint these days. I have been most familiar with Pettit & Interlux on my 1963 '37 Connie. What offers the greatest protection while not creating a difficulty with the CAPAC system?
    Please be specific if you would, about surface preparation. The hull will be blasted in a few weeks.
    Thank you, in advance.
  2. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    That Time of Year
    Getting ready to pull her out, eh?
    Well, E- Paint is the way to go nowadays. I used to use TRILUX until they quit making it (something about legal stuff). Anyway, thatz who I go to for bottom paint.
    1. EP - ZO (Available in multiple colors):
    http://www.epaint.net/products/zo_tech.shtm
    2. Ep-2000 (no copper): http://www.epaint.net/Merchant2/mer...e=BP&Product_Code=EP2000GA&Category_Code=Anti
    Only two colors - gray & white
    Surface preparation - generally I recommend turning your metal hulled boat into a fiberglass bottomed boat - this, by biting the bullet and stripping bottom down to metal/fairing.
    For aluminum, you would then "wash" with alodine (to obtain a bit of grip for the paint), and then apply a coat zinc chromate (baseline protection).
    Not sure what exactly to do for steel (see articles here: http://www.geocities.com/alloyed2sea/TechnicalForum.html)
    IN any case - once prepped, then, coat bottom with 4-5 coats of INterlux 2000E Epoxy (http://www.pyacht.net/cgi-local/Sof...re/h-interlux_interprotect_2000.htm?E+scstore) - as a barrier coat/protectant. This creates a "barrier coat" - keeping the water away from the metal. This way, you pretty much eliminate surface corrosion
    Now apply your E-Paint (2 coats) once every year or so.
    Proper zincing will also help - salt water? Itz more art than science - so you'll need to find you own "mix" (zinc/magnesium) depending on local conditions. Look around the marinas at other metal boats.
    Good advice on that issue can also be found here: http://www.metalboatsociety.com/
    IN any case, hope it all works out.
    Keep up the good work!
    Cheers,
    Eric
    "Tin Tonic"
    1967 CC Roamer Riviera 37' (AL)
