Click for Walker Click for Northern Lights Click for Cross Click for Glendinning Click for Abeking
57 Ocean Drain Line Clog
Discussion in 'Ocean Yacht' started by Final Act, Aug 4, 2016.
  1. Final Act
    Final Act New Member
    New Jersey
    Hello. I have an '04 57 Ocean with a pesky problem I'm trying to fix. Salon AC air handler is on the bridge and drains to a "T", then a hose that disappears into the boat. The other side of the T goes to a locker on the bridge with a drain hole. The locker is filling up with the water draining from the AC, because somewhere there is a blockage in the line. I took the T apart on the bridge, used a compressor, hose and a snake, as far as it would go. Out of frustration, I even tried Drano. Blockage is in some other part of the system. Apparently the cockpit sink drains through the same thru-hull and is fine. Before I tear the boat apart, any ideas?
    Sunseeker loves using Ys for their a/c drain hose and inevitably once a year or twice on this one boat, the same thing happens, it is always at the T and usually algae buildup. A garden hose nozzle tends to work better than compressed air.
