Click for Burger Click for Abeking Click for Burger Click for Mulder Click for Westport
53 Navigator rocks with auto pilot on
Discussion in 'General Yachting Discussion' started by Worthyvess, Apr 19, 2016.
  1. Worthyvess
    Worthyvess Member
    South shore long island and fort lauderdale
    Does anyone know why our 53' Navigator would rock in calm water when we put the autopilot on? Thanks for any input!
  2. Iknownothing
    Iknownothing Member
    Lauderdale
    What brand autopilot? Sounds like the rudder sensitivity is set too high.
  3. olderboater
    Regardless of brand, it sounds like a sensitivity issue and you just need to adjust the autopilot.
    This. You can usually adjust the sensitivity ( could also be called response) in the menu and should adjust it from time to time for various sea states/conditions.
  5. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    You guys are good!
    I'd have suspected the bilge rats endemic to that particular autopilot model scurrying back and forth between the sensor and the pump as the cause of the rocking.
  6. Worthyvess
    Worthyvess Member
    I agree - they seem to know everything! Thanks for all the replies. Will now investigate settings.
    What brand autopilot do you have? If simrad, put it in auto mode (can be at the dock), then hit the NAV/setup button twice (in rapid succession) you now will go to a menu use the right arrow to scroll down and the knob the adjust, when done just hit auto again..... 2 clicks (one notch on the screen) left will probably fix the issue.....although I adjust the settings all the time on boats I run.....if in the ICW I turn it up.....if in the ocean turn it down.......also if you hit auto twice in rapid succession the autopilot will go in Hi mode and respond faster, if you back the response off this comes in handy as well.
  8. olderboater
    Find a manual and read it, whatever brand it is. You may find some other very useful features you aren't aware it has.
  9. Worthyvess
    Worthyvess Member
    I forgot to answer what brand it is - Raymarine. You guys have given us so much help! I think my husband will work on this today - I'll let you know how he does!
  10. Worthyvess
    Worthyvess Member
    You guys have all the answers and I just got a trophy! Doesn't seem right somehow lol!
  11. Capt J
    On those Raymarine calls it response, and you just go through the menu button till response pops up and then use the down arrow to adjust it once the screen reads "response and a #". You may have to be in autopilot mode to do this
  12. Worthyvess
    Worthyvess Member
    Thanks Cap J. He did find the response adjustment. Can't check if that will do the trick until the exhaust is fixed and he can take it out.
