Click for Cross Click for Abeking Click for JetForums Click for Westport Click for Burger
46 Post interior wood work
Discussion in 'Post Yacht' started by RT46, Feb 22, 2011.
  1. RT46
    RT46 Senior Member
    Does anyone know what the interior cabinets and finish on a 1988 46 Post is?
    It appears to be be Teak plywood with a yellowish stain.
    Im trying to match and blend some repairs.
    so far no answer from Post Yachts.
    Regards
  2. SeaEric
    SeaEric YF Historian
    out on the dock
    Its probably a combination of teak and teak veneer over plywood. It will be very difficult to match existing finish due to the color change that teak experiences over time. New teak will be much darker. You may have to go with a wood with similar grain in a lighter color, then do some custom stain blending to get it close. Its been my experience that Seafarer in Ft Lauderdale stocks many veneers. If you can pay them a visit or send them a sample, they can be very helpful in suggesting what may work. Veneer is easy to ship as it rolls up and goes in a tube. Good luck with your project.
  3. RT46
    RT46 Senior Member
    Answer in owners book
    I found the answer to my own question my Post owners book:
    I hope this is helpful to anyone with the same question:
    AS PER POST OWNERS BOOK 1988 46':
    " Paint 43' and 46' "
    Entire Exterior of boat is Interlux Exterior Gloss White #87, Mixed W/Ivory Interlux#224 (approx 8 oz/Gal.) to match Gelcoat.
    Inside Colors are tinted using the Z-spar Gloss#100. Wood finished with Interlux#60 Rubbed effect Varnish.
    Stained Polit Houses, Doors & Drawers are McCloskey's Tungseal, Walnut Penetrating Wood Stain or Dupont Barnwood Stain ##1045C.
    Exterior - - - Bridge Parts & Moulding around shelter are Teak finished with Dolfinite#110 Spar Varnish.
    Teak treated with Tip-Top Teak (or equal) Mfg. by Tripple T. Enterprises, Inc., Palm Gardens Fla.
    Engine room - - Interlux #289 Miami Tan & 50% Z-Spar #105
    Boot Stripe - - Awl Grip Colors to Suit from chart
    Teak Interiors are sealed with Interlux sanding Sealer #X9297 then finished with #60 Interlux Rubbed Varnish
