Click for Abeking Click for YF Listing Service Click for Nordhavn Click for Northern Lights Click for Burger
444 - Cruise Speed/rpm
Discussion in 'Carver Yacht' started by ksbguy, May 30, 2013.
  1. ksbguy
    ksbguy Member
    Water
    Anyone have an 01-06 444 here with TAMD63P 370 volvos (2800 rpm motors)? I'm trying to compare cruise speed/rpm. I'm propped at 40rpm over WOT right now and I'm at 17 knots at 2400 rpm with tabs all the way down.
    Thanks!
  2. hopper5
    hopper5 Member
    Olympia,wa
    For what it's worth my 1994 440 with Cat 3116 (300 hp) is about the same top (!7 kts)end despite all the other claims I hear of higher speeds......I even tried larger trim tabs to get the nose down to help plane out but that's all she does !! I find it's perfect and comfortable at about 1800 rpm's and 9.5 knots.......right around hull speed. The motors are also 2800 max rpm motors.
  3. ksbguy
    ksbguy Member
    Water
    Thanks for the response.
    My motors are 370HP rating and the top is closer to 21 knots. My cruise is 17 knots. You have a bit smaller motors so your numbers make sense... At the end of the day you need horsepower to produce speed so more tabs won't do much other than possibly help you get out of the hole a little easier and maybe stay on plane at slightly lower speed. Make sure you reach at least 2850 rpm WOT so your EGTs are not high - pitch down if you have to...
