I just purchased a 44 HTX and Starboard side window is leaking into hall and causing water to come thru cutting board and into eng room. I was wondering if anyone had this issue and if they know how to fix. I have fixed everything all pumps/steering ram/cushions/electronics/etc. only real issue is water leak.
Hi John and welcome to YF. This issue has come up many times here, and in fact a few times recently. Click on the SEARCH feature above, put in windows and click search. You should easily find your answer.
Cabo had issues with those sliding side windows leaking and I believe stopped putting side windows after hull 7. I don't know the fix for you, perhaps make sure the drains are clear and etc.
