Good Afternoon. Just purchased a 3207 Carver about Two Months ago, love the Boat. Pulled it out of the water for the winter and started to winterize it, but can't find the drain plug anywhere...Had a sea strainer leaking which left a little water in the bilge, want to remove it so it doesn't freeze. No manual with the boat so I'm reaching out with a Silly Question.
You mean a drain plug like what you would see on a boat that goes on a trailer? You won't find one. To remove the water you will need to pump it out or if it is only a small amount, a shop vac works well.
