I need to buy a 32 volt DC bilge blower with 4 inch hose openings. Any suggestion on where this and other 32 volt equipment can be found would be appreciated. New or used. Also need a 32 volt converter 110 to 32 volt 30 to 40 amp Capt Bob Cerullo email: REMOVED
You need a whole blower or just the motor? 32Vdc motor part number 30200-0020. Whole 32Vdc blower part number 35440-0020 . If your keeping your 32Vdc boat, You must stock spares. These parts are not on any local shelf.
The housing is good. I need the motor, blower wheel and if possible the bracket Any ideas where to buty it?
Blower wheel 35714-0000 . Bracket 43899-0000 . Google search the part numbers on a desktop computer. A common supplier will develop.
I've had to buy a 12 volt or 24 volt complete blower assembly and then replace the motor with the 32 volt motor that Capt. Ralph mentioned. I replace the whole thing. If it needs a motor and blower wheel, what's the point of not replacing the entire thing?
One other thought, If your using the blower continuously, in a diesel environment, the 120Vac motors will run & last near forever. The Vdc motors will die in a few hundred hours. The Vdc motors are not rated continuous. Vac motors are.
Jabsco does make a continuous duty blower with a 5,000 hour motor life rating. BUT, I don't think they make it in 32 volts. 35770-0092 (12 volt) and 35770-0094 (24 volts) 4", they're only about $50 more than the normal ones, so I always replace with these. They also make 3" continuous duty blowers in 12 and 24 volts.
I found the 32 volt blower motor from a great source Reliable Industries, 5739 G Street, Harahan, LA. Mark Tillman there is terrific. Great people to wok with. They are on the web.
Was doing a search for a 32V blower motor. Not on the top but this page came up in the top 5. Pretty good for our site. Good show Carl.
