Anyone have any information regarding this generator? As far as I know they are good generators, but how do these compare to other brands? For how many hours can they go without rebuild?
If you are thinking of the model from the early 90:s, I think it was based on a John Deere, I had a couple with no issues over five years. Only one starter got a crack in a forged part giving an earth fault that was hard to track down.
Have never had a problem with Northern Lights, in any flavor, 30KW, larger / smaller. Other than expected ware and tear, it's an awesome genset.
i have 3 northern lights on the boat i currently have and the 40 kw has 27000hrs on it now and still works very well the 30 kw has 22000 on it and the hotel gen set 22 kw has 31000 on it all i do is change oil every 150 hrs and do the overhead every year other than routine maintence a couple of water pumps starters and alternaters every thing is still 1988 model hope this helps travler
I think our oldest genset only has about 12,000 hours on it total, but same thing as traveler- maintained on a regular schedule, service as needed, and you'll get a good long life out of it. My Father has a Northern genset in a camper / trailer that probably has 40 or 50K hours on it. Still runs like a top. Other than brushes and normal service, it too runs like a top.
I was told by Northern lights they'll go 40k hours in a commercial 24/7 (more or less) use setting and less hours in a pleasure boat. They are a great genset, parts are cheap in comparison, and much better then Onan, Westerbeke, Kohler IMO
KIWI when i do the overhead i do the valve lash check the valve springs check the cam timeing if it is starting to change i look for geartrain failure check the timeing on the fuel pump & usualy leak the motor down does this help travler
