Click for Westport Click for Westport Click for Nordhavn Click for Ocean Alexander Click for Northern Lights
2 year old Northern lights with 61.7 hertz under load
Discussion in 'Generators' started by motoryachtlover, Jul 17, 2019.
  1. motoryachtlover
    motoryachtlover Senior Member
    smithfield, VA
    My 2 year old northern lights 20KW genny shows 61.7 hertz under load. Is this a problem? Thanks for your time.
  2. Pascal
    It s a little high if under a full load. What do you get lightly loaded? Won’t really hurt anything though.
  3. Capt Ralph
    Your old 120Vac clocks may run faster.
    62 htz will not hurt anything.
    It's just a minor/micro governor adjustment.
    With a good freq meter you can do it your self but at 62 htz, not a worry.
  4. motoryachtlover
    smithfield, VA
    Thank you both for your responses
  5. Capt Ralph
    Remember, at 1000 hours you have a cold valve adjustment. Order your new spaghetti top valve cover gasket and air filter.
    Have a quality htz meter and adjust all then.
    Usually at the first 1000 hours I really rinse the sump and if not already using it, change to Shell T5 10w40.
    New belt, eye ball the raw pump real well.
    Back flush the H E.
    Dip the coolant and adjust coolant supplement. Fix all leaks.
    It's all in the manual.
  6. 55 Sea Ray R
    55 Sea Ray R Member
    Naples FL
    I have a Westerbeke and the guy told me 58-62 is ok.
